offroadTB.com • View topic - MDB Steel Bumpers...
Moderator: bartonmd
by fishsticks » Thu Mar 10, 2011 5:21 pm
Looks good mang. 8-)
by HARDTRAILZ » Thu Mar 10, 2011 5:25 pm
by janesy86 » Thu Mar 10, 2011 5:29 pm
by Trail X » Thu Mar 10, 2011 5:43 pm
by HARDTRAILZ » Thu Mar 10, 2011 5:46 pm
Mikes are simple to remove
by djthumper » Thu Mar 10, 2011 5:50 pm
That looks good!
by JamesDub » Fri Mar 11, 2011 10:06 pm
How far in front of the holes on the alum oil pan skid plate do you need to cut to modify it for installing the rad skid ?
The DubMobile is getting a makeover !
JamesDub
by dirty anton » Fri Mar 11, 2011 11:08 pm
on my steel rad and oil pan skids, the ends overlap and share the same bolts. if you have bolt protectors on your oil pan skid you would have to grind or cut them off so the rad skid would lay flat over the end of the oil pan skid
dirty anton
by JamesDub » Fri Mar 11, 2011 11:43 pm
I dont have the bolt protectors . I have read that for ease of removal of the oil skid to change the oil you should cut off a bit of the overlap . Heres a pic I saw in a thread somewhere ....
JamesDub
by dirty anton » Sat Mar 12, 2011 12:48 am
if i take off the 4 bolts i can slide the oil pan skid out from under the rad skid. however i got both of these skids at the same time. maybe it was made a little different for ease of removal. i would think you could cut it off an inch or so after the bolt holes so you dont have as much to slide out from under the rad skid.
dirty anton
by Gordinho80 » Sat Mar 12, 2011 1:30 am
I mounted my oil skid over the rad skid.. No bolt protectors but if I had them, I wouldn't have to grind them down. Easier to drop skid for oil changes...
Mario -
by dirty anton » Sat Mar 12, 2011 2:23 am
i see now jamesdub, the oil pan skid curves up in the front. you see mine came flat. should be good tho if you cut that off.
dirty anton
by JamesDub » Sat Mar 12, 2011 2:40 am
29 dollar task force recip saw from my work at lowes cut it off . Blister + bent blade + job done = priceless .
JamesDub
by HARDTRAILZ » Mon Jun 13, 2011 10:04 pm
A trip around the new bumper...
by That1Guy » Mon Jun 13, 2011 11:36 pm
Previously known as NickNorie
That1Guy
DriveTrain: 2WD w/ G80
by navigator » Tue Jun 14, 2011 8:06 am
Hardtrailz, is that a different bumper or your old bumper in black?
I like the look!
by HARDTRAILZ » Tue Jun 14, 2011 8:12 am
by navigator » Tue Jun 14, 2011 8:47 am
Awesome, it looks good. I think the black breaks up the white nice. It goes well with the "backwoods edition" :-)
by bartonmd » Sun Jul 24, 2011 9:41 pm
Kyle came over today to help me put a brush guard on SteeveO's bumper, and to help me tack up DJones' bumper; and we went ahead and bent up some tube for a light hanger / deer catcher on his bumper...
by NC_IslandRunner » Sun Jul 24, 2011 9:50 pm
NICE!!! I want one :drool: ....F@%king tranny :evil:
Return to MDB Fabrication
