offroadTB.com • View topic - New Lift Design (need some input)
Products offered by our vendor: markmc
Moderator: markmc
by fishsticks » Sat Nov 27, 2010 4:13 pm
Something is amiss here... my pre-body lift hub to fender was around 23.5-24. That's 4" of suspension lift. If you are 22.5" now, that's 2.5-3ish inches of lift...which is right where you should be.
Are your springs terrible or something?
by Opeth » Sat Nov 27, 2010 4:45 pm
So overall, the new design is giving 2.5"-3" of lift? How are the angles of your CV shafts and upper ball joints?
by Hpimichael02 » Sat Nov 27, 2010 5:20 pm
Hpimichael02
by Hpimichael02 » Sat Nov 27, 2010 5:28 pm
I'll take the bumper off tomorrow and I'll give you guys that measurement so no ones confused and we can get a better idea if it lifted it more. But it did go up from 21" to 22.5", but if anything I think it'll be marketed at 2.5-2.75" lift set up like the older set
Hpimichael02
by markmc » Mon Nov 29, 2010 5:05 am
markmc
Rank: Mall Rated
by Hpimichael02 » Mon Nov 29, 2010 8:21 am
I'm gonna take the bumper off for a couple weeks due to some mods so we will see if it pops back up a Lil, but the new design did look much thick than the whole old assembly, we can always hope right lol
Hpimichael02
by HARDTRAILZ » Mon Nov 29, 2010 9:14 am
by Zero » Mon Nov 29, 2010 2:20 pm
So to understand, this n" new in design 3" lift" is only giving 2.5-2.75" of lift? Does that mean the design failed? or is that in the area of lift you were looking to achieve? Currently I have sagging soft springs, and the bds2" lift. So anything to get me up a lil higher would be great. I also wondered if you are using the same poly bushings as the BDS kit? or if this new design gets rid of them entirely.
by Trail X » Mon Nov 29, 2010 2:40 pm
by Opeth » Tue Nov 30, 2010 9:03 pm
Some install photos and measurement pictures would be a good thing to have right about now. Before's and after's...
by HARDTRAILZ » Tue Nov 30, 2010 10:16 pm
by Opeth » Wed Dec 01, 2010 1:03 pm
by Trail X » Wed Dec 01, 2010 1:08 pm
by HARDTRAILZ » Wed Dec 01, 2010 1:12 pm
When I get my hands on one of the kits I will get pics and measurements...if I have it soon enough I can install and test at badlands on jan 2nd.
Feel free to request what pics and measurements will help ya'll out and will do my best to provide them
by Hpimichael02 » Thu Dec 02, 2010 11:53 pm
Old design
Sorry it's floor to fender didn't do a hub to fender then
Hpimichael02
by Hpimichael02 » Thu Dec 02, 2010 11:55 pm
New design
(pic tomorrow)
New measure is 37.5 is what I measured will redo again but old dewing was around 36.8"
And that's after the winch bumper was on so it's settled with the offloading yesterday lol
Hpimichael02
by Opeth » Tue Dec 07, 2010 8:05 pm
I have most concern with CV half shaft angle. I haven't figured out which springs I have as of yet, but when I do the suspension I will most likely be swapping in 87's or 88's with one of marks lifts. I already have reserved one of the recent runs of his 3" body lifts. This is my daily driver so lay up time has to be kept to a minimal. I can't be eating through half shafts 2-3 times a year, that is probably an extreme case in itself.
I do like to keep to originality, but when it comes to suspension I have learned my lessons when I was younger with tuner cars and take them seriously. ( First suspension were cheap $99 springs on factory stock struts -- Damaged more than I am willing to admit, last suspension before I parted the car out was a $1,700 TEIN Super street coil over set up with an electronic dampening force controller) Please don't be offended Hardtrailz but I am modeling my lift setup after yours, down to the 305's in tires.
When you get the new lift, can you take pictures of the stressed components ( Upper ball joints and half shafts with old lift and new when your finished?) It would be greatly appreciated, thanks!
- Cody
by fishsticks » Tue Dec 07, 2010 8:16 pm
FWIW I don't think anyone here has broken a CV shaft due to angle concerns.
Springs/lift choice won't have any effect on the CV maximum angle. Only adding lift to the outside of the assembly (or lengthening the strut rod) will increase maximum angle.
by Hpimichael02 » Fri Dec 17, 2010 12:53 pm
kyle you got yours yet ???
mark call me when you can
Hpimichael02
by HARDTRAILZ » Fri Dec 17, 2010 1:09 pm
Not yet
Return to Liftmeister
