offroadTB.com • View topic - New Lift Design (need some input)
Products offered by our vendor: markmc
Moderator: markmc
by Hpimichael02 » Tue Nov 02, 2010 7:45 pm
Well I def. Don't mind taking my suspension on and off, it needs to cone off for springs and shocks, bit also what cones with the free parts is that you have to swallow the cost of any damages I.e. A catastrophic failure in the strut and tire falling into upper fender , not sure if that's valid possibility but you get the point
Hpimichael02
by Hatchet669 » Wed Nov 03, 2010 2:11 pm
well mark you always know i'm available for any help needed... even at a cost if need be as i know its not cheap...
Hatchet669
by Trail X » Wed Nov 03, 2010 3:42 pm
If anyone tests these... I hope they actually go off road with them. :shoot:
by HARDTRAILZ » Wed Nov 03, 2010 4:33 pm
by janesy86 » Wed Nov 03, 2010 5:00 pm
:Iagree: And I know Kyle is gunna beat on it good. Lookin' forward to see the progress!
by markmc » Sun Nov 14, 2010 11:47 am
Ok Here is an update.
4 prototype pieces are being machined this week by Jimmy at wheeladapters.
The first set will be installed on Hpimichael02`s truck (Nov 27th)for test fit cus i need to be there to ensure fitment.
The second set (after test fit meet) will go to Kyle for more testing..
Kyle:
sending you some pics, if you could post them please??
markmc
Rank: Mall Rated
by HARDTRAILZ » Sun Nov 14, 2010 7:39 pm
by DmccartneyFF2TB » Sun Nov 14, 2010 8:08 pm
Dame
BDS,ROUGH COUNTRY,
Smitty Build XR-C8 Winch
www.wm4x4.com
DmccartneyFF2TB
by fishsticks » Sun Nov 14, 2010 8:14 pm
They look like at least 3".
I like that you tapped a hole for the 3rd bucket hole. How far down are the other two studs tapped? Were you able to sink the shock rod tube down much to get anymore length out of the shock?
by dirty anton » Sun Nov 14, 2010 11:45 pm
lookin awsome mark keep up the good work :drool3: mike b.
dirty anton
by markmc » Mon Nov 15, 2010 4:43 am
markmc
Rank: Mall Rated
by DmccartneyFF2TB » Mon Nov 15, 2010 8:10 am
Sweet!!!! i cant wait you have a possible price?
Dame
BDS,ROUGH COUNTRY,
www.wm4x4.com
DmccartneyFF2TB
by DZPearl » Mon Nov 15, 2010 3:43 pm
Very nice job on the new design. I have been following this for the most part and may be confusing ideas given with the actual design itself. I guess that I am looking for a little additional clarification on your newest design. I understand that this design was to eliminate the upper mount/bushing like BDS and Rough Country. And my understanding was that it was going to create lift through compression like the old design but incorporate additional lift by external means without the need of the 1/2" spacer. But I also thought that the design was to relieve spring stress so that someone could use stiffer springs while keeping the strut from possibly topping out. It may be an optical illusion but it seems that this design would create more tension than the prior design. Is there any insight that you can give me on this? Maybe I just need to see it mounted.
As a side note, this post is not an attempt to knock your design by any means. Your products have always been top notch and cutting edge in my book! Without your assistance there would not be as many lifted vehicles as you have absorbed a lot of costs thus helping everyone.
We have come a long way from when I purchased my vehicle new in 2003. At that time I don't remember seeing or finding a lift for our platform. I thought that the only way I was going to get any lift was to write Monster Garage for help. Thanks again Mark!
DZPearl
DriveTrain: 2WD w/ G80
by Trail X » Mon Nov 15, 2010 4:18 pm
Mark, make sure there is a generous radius (10mm+) on the transition between upper shock mounting plate and the spacer body to prevent stress concentrations.
by markmc » Mon Nov 15, 2010 4:25 pm
markmc
Rank: Mall Rated
by markmc » Mon Nov 15, 2010 4:32 pm
markmc
Rank: Mall Rated
by Zero » Mon Nov 15, 2010 4:56 pm
I def want to revamp all my suspension parts. quick disconnects, skyjacker rear coils, bds shocks, and up front i will need new struts and springs soon. Id consider selling my BDS front lift to help pay for yours since it will give me a bit more lift.
keep up the good work. i hope these test well and we get access sooner rather than later.
by markmc » Mon Nov 15, 2010 5:21 pm
markmc
Rank: Mall Rated
by Hatchet669 » Mon Nov 15, 2010 7:44 pm
i as well mite be selling my BDS and redoing my suspension... since i need to replace a few parts due to wear... so mite as well go big on the way back...
Hatchet669
by HARDTRAILZ » Tue Nov 16, 2010 9:19 am
:excited: I can't weait to see how this shakes out. Several day trip to parks for events this time of year. Toys for Tots has runs at about every park around. Many benefit runs for Christmas and things, so I should be able to test them out.
Return to Liftmeister
