by fishsticks » Sun Nov 14, 2010 3:39 pm
dlcsjoyce wrote:The bolts are 1/2" that was the biggest drill bit I could find at the time, and they are in it just to mock it up. I plan on using grade 8 bolts to hold everything together and regular hitch pin above the pivot point. I still plan on cutting a piece for a hi lift jack but not having on to go by I need to figure out about how long and the bolt spacing to bolt it down. Thanks for the input it pushes me to try and finish asap.
My hinge is a 1/2" grade 8 bolt, and my pin is a 1/2" pin. Zero issues.
Step bits are your friend.
02 TrailBlazer LTZ - 35s, lockers, balls - Gone but not forgotten -
Build
