bgwolfpack wrote: I hadn't thought about the grounding issue with the vehicle. You seem to be the "right guy" to ask about these things judging from your link.
Where do you think a CB antenna should be located on this vehicle type?
LOL, I am the communications technical director for that race. So basically I engineered the voice and digital networks for the race and have assisted several of the teams get their communications working properly.
As a standard the best location on any vehicle is going to be the center of the roof. It provides the most even ground plane around the antenna. But I know for most of us that is out of the question due to then we can't put anything else up there. If you have a full roof rack you can get a mirror mount and use that. I would have to see what kind of continuity we have between the roof rack rail and the body to see if it will provide enough bonding to provide a decent ground plain. Mounting it higher will aid in you hearing more and being heard better.
I haven't gotten all of my antennas mounted permanently yet because I still need to get a rack and stuff up there. So presently I have them just on mag mounts. Mind you these are ham radio and GMRS radios at this point, I will be adding a CB to it.
