by The Roadie » Fri Apr 23, 2010 12:34 am
Sorry - didn't get back to this right away. I don't care what the rake looks like or what the MPG penalty is, and I was maybe the first one to scrape frame rails a LOT on a trail I got obsessed with climbing, so I was speaking from experience and 31.5" tires when I said I like the way the truck gets unstuck if it's higher in the back.
I also overcompressed and had to discard two sets of OEM springs for taking a permanent set. Three if you count a set of fronts I had to discard. And all this in only 80K miles.
And with the cantilevered spare carrier on the back, rear spring stress is even worse than stock design, and I really never take out the full earthquake/wildfire bug-out-supply gear. The Roadiemobile is a survival tool, not just a daily driver.
I consider the Z71 springs essential also for their higher and progressive spring rate, to reduce the number of times I hit the bump stops. And to allow for a larger diameter Airlift bag for more compensation force per PSI of bag pressure.
Perhaps I overstated it, but I do tend to forget that other folks carry a lot less stuff. The springs can allow you to skip a rear spacer if all you want is a small lift, because a spacer on an OEM spring can mash it flat if you don't also add thickness to your bump stops. It's less likely to mash a Z71 spring flat.
AlekG's LIFTED Tahoe springs give 2.5" lift on a Tahoe, and 4" for us. I would have put those in except I use a WD hitch to tow my trailer 8-10 times a year, and an extra couple of inches would max out the adjustment range on my drop mount.
Anybody wanting to do a vernier adjustment, I have a couple sets of rear and one set of front 1" SMAXX spacers to sell cheap. Damn, and I know I owe you an email about some stuff, Kyle. Sorry. Political fight at work has me on edge.
