Air box
by cpyonker » Thu Dec 07, 2017 11:37 pm
I didn’t know where else to put this but I was interested in relocating the air box farther up so as too make finding a snorkel easy
cpyonker
by Regulator1175 » Fri Dec 08, 2017 3:56 am
If you figure it out please let me know! I have the snorkel, but have been debating the air filter box for a couple months now and it just cost me a motor.
by KingBird » Sat Dec 09, 2017 1:37 am
My idea has been to 90 the intake pipe into the wiper cowl.
Getting to the filter would be fun, but since I've been in some deep stuff and never sucked water into my vents, it's gotta be better than nothing. Plus, if the water is deep enough, you're gonna short out the electronics under the hood anyway...
KingBird
by Regulator1175 » Mon Dec 11, 2017 3:25 am
there isn't room for a filter inside the cowl, and that only gives you about another 1 above the ground. The snorkel I have in place already, my problem is deciding on an air box that will serve my needs.
by Trail X » Mon Dec 11, 2017 9:44 am
This is the filter you need:
viewtopic.php?f=11&t=366&hilit=f150&start=100#p84879
F150 4.6L V8, unknown year, I believe its early 2000s.
by TBYODA » Mon Dec 11, 2017 12:30 pm
I know Nate Schroeder is using a k&n apollo intake but he removed the stock window washer reservoir and coolant replaced with smaller units.
by TBYODA » Mon Dec 11, 2017 1:05 pm
by Trail X » Mon Dec 11, 2017 1:52 pm
Looks like he also doesn't have A/C.
by Regulator1175 » Thu Dec 14, 2017 1:16 am
Trail X wrote:This is the filter you need:
I have had this filter box sitting in the garage for 6 months, it is huge though! AC is a requirement in my truck so I am trying to figure out my available real estate for it. I have been toying with the idea of making my own using aluminum with a plexi top.
by Regulator1175 » Thu Dec 14, 2017 1:18 am
TBYODA wrote:
I feel like you are loosing to much airflow with going to such a small filter set-up. The filter in that is half the size of our stock filter.
by Trail X » Fri Dec 15, 2017 12:07 am
I figured it was big to work with that engine, but I wouldn't think it's particularly oversized for ours. I have never seen one in person though. Agreed, gotta keep the AC... although getting rid of it might solve my overheating...
by TBYODA » Sat Dec 16, 2017 1:16 am
Trail X wrote:I figured it was big to work with that engine, but I wouldn't think it's particularly oversized for ours. I have never seen one in person though. Agreed, gotta keep the AC... although getting rid of it might solve my overheating...
I bet you got years of mud packed in the condenser and radiator. I pulled the front apart last year and had a ton from the little wheeling I have done to date. I separated condenser from the radiator and made a attachment to garden hose with flared 90 so I could get all the way down. Also add some wetter water to the coolant. Could also abe few other items like water pump but I am sure you have ruled them out already. :P
https://www.amazon.com/Red-Line-80204-W ... automotive
by cpyonker » Mon Dec 18, 2017 6:04 pm
Thanks guys I will keep searching for a way to relocate the air box as it is a big concern. Haha I can’t afford a fresh engine.
cpyonker
Return to Fab Work
