by Trail X » Fri Nov 03, 2017 4:29 pm
If you can tell us the relative frequency of the vibrations, it may help us understand the situation. Is the vibration at the same speed of wheel spin? Is it slightly faster (3x), significantly faster (6x)? Slower (1/2x)? Slow vehicle speed or high vehicle speed or both? Each may correlate to a feature of the vehicle. For instance, if 3x, then it would likely point to a tripod joint.
If I had to guess, I'd guess that your tripod joint on your passenger side has significant play (reach in and push up on the tripod housing with a lot of force, if you can move it more than say 1/8", you may need to rebuild your disconnect. Also, grab your CV shafts and try to muscle them around. If you have play in any of them, it may be time to replace a CV assembly. If you only have high speed vibrations then it may indeed be an alignment issue alone, in that you are hitting a resonant frequency of the steering system.
Get under there and start inspecting. Report back.
