by HARDTRAILZ » Mon Nov 07, 2016 9:55 am
Not mine, but doing a disco rebuild on an Envoy for a co-worker currently. Got it all apart yesterday and confirmed it needs a couple bearing and outer seal to be back to good. Swapping CV as well since it showed some spline wear.
by DirtyBacon04 » Mon Nov 07, 2016 2:07 pm
Discos are actually kind of fun to rebuild. I sincerely enjoy doing them...
by HARDTRAILZ » Mon Nov 07, 2016 2:22 pm
I would not do it except for good money. Hate taking the shit apart to get to it and messing with the grease. Dreading putting it back together. Simple job, but for some reason this one is not a fun one to me, but neither are CVs and this requires same damn work.
by DirtyBacon04 » Mon Nov 07, 2016 2:47 pm
i put the grease on my face and pretend I'm a god damn war hero
by HARDTRAILZ » Mon Nov 07, 2016 3:09 pm
That is part of it right? I mean its in the freaking write-up....War Paint and run naked thru suburbia while chuggin Natty and waving an offroadtb flag!
by bljis123 » Wed Nov 09, 2016 11:12 am
ROFLMAO, I'll be doing the same thing soon, but I cheated and spent the money for a new one. War paint still with natty ice and my new offroadtb sticker. get er done!
2003 GMC Envoy XL SLT 4x4
bljis123
Vehicle: GMC Envoy XL
by HARDTRAILZ » Thu Nov 10, 2016 9:06 am
Oops...
by Trail X » Fri Nov 11, 2016 2:23 pm
Did you buy a set? Those look gnarly.
by HARDTRAILZ » Sun Nov 13, 2016 9:17 am
En route. Deal too good to pass up.
by bljis123 » Mon Nov 14, 2016 3:22 pm
:cheers: Officialness.. esss...
bljis123
by HawkeyeC25 » Thu Nov 17, 2016 12:10 am
Took the oil pan out so I could pull the front diff and find my oil leak. I found that the inner axle seal was leaking and dripping down and coating the oil pan AND several of the oil pan bolts were not even finger tight!! Rear main looks fine, but I've got some cleaning to do on this pan and windage tray.
On another note, I ordered up 4.56 gears so now I have to drop the rear axle and bring them both in for install :excited:
HawkeyeC25
by Mirage » Fri Nov 18, 2016 6:04 pm
Installed my brakemotive d/s rotors and pads. Also new steelies Image
Mirage
by Trail X » Mon Nov 21, 2016 6:26 pm
Dropping that pan probably wasn't very fun Craig. Amazing how much gunk is inside these engines - they don't look like the oil commercials.
Love the wheels Cory. Are those just spare tire steelies for the TB? Where did you pick them up? Post a picture when you get them on the road.
by HawkeyeC25 » Tue Nov 22, 2016 9:26 am
HawkeyeC25
by NC_IslandRunner » Tue Nov 22, 2016 8:05 pm
Washed the outside down, ordered 5 new tires I should have tomorrow afternoon! Clean out the inside and drop it off at the shop tomorrow or friday.
by HARDTRAILZ » Tue Nov 22, 2016 10:27 pm
My tires said 8-12 weeks
by Mirage » Tue Nov 22, 2016 10:35 pm
Mirage
by bljis123 » Wed Nov 23, 2016 10:47 am
How do you like those breaks? I need to upgrade soon, I have Napa adaptive one on both cars and after a year they suck. Don't like them.
I changed oil and did the VVT valve just in case. You do have to take off power steering pump to pull all the way out. Simple 1 bolt on VVT.
Noticing some vibration, may be my offroading, will need to look at motor mounts over holidays.
bljis123
by Mirage » Wed Nov 23, 2016 5:00 pm
Mirage
