by larryk » Tue Jun 28, 2016 11:54 am
Here are mods I have found to be helpful for the 4L60E. Some may not be needed, but I try to go for strength and overkill.....
Corvette or Sonnax 2/4 servo, with Sonnax o-ringed apply pin; beast (or Sonnax) sun shell; 5 pinion GM planetaries (avoid the aftermarket chinese knockoffs!); I use borg warner clutches/bands.... Avoid the temptation to go to an extra plate in the 3-4 clutch pack, it ends up warping the steels, and burning it out prematurely; kolene steels in all clutches; new input drum anytime the band is changed; Transgo shiftkit/seperator plate; GM deep pan with factory drain; updated valve body with TC valve sleeve replaced; .500 boost valve; tcc regulator valve in the pump....and now that I have seen it.....Id suggest a billet 13 vane pump hub too.
Rebuilding a trans really isnt that tough, you just need to have a CLEAN area to work in, take your time, and make sure you prelube/soak all parts/clutches when you install them. Do not want a dry start..... Replace EVERY bushing/seal when you are in there and do not force anything.
