offroadTB.com • View topic - 4x4 Disconnect Busted... Now What???
by mason10198 » Sun May 01, 2016 11:01 am
Alright guys... I lost my 4x4 yesterday to the fracking aluminum shift fork in the disconnect. Bearings in it got destroyed on the way home from the internal shrapnel, so if I hit 30+ MPH the CV started flopping around so bad I thought I was gonna crack the oilpan. I've got it taken apart in the garage right now, but I NEED it back as soon as possible.
My question is, what is the best thing to do now? I've seen where people have replaced the fork/bearings/seals in the disconnect and slap it back on, or buy an entire "improved" version of the disconnect off of amazon/ebay, or totally forgo the fork and use the AWD sleeve/weld the gears together.
I don't want to keep going through this PITA bearing-hungry disconnect rebiuld... I like the idea of leaving the fork out completely, but then my 4x4 isn't selectable... right? What EXACTLY would be the result of me using the AWD sleeve? Wouldn't that make it permanently 4x4, not safe to drive it on roads? This IS my DD, so permanent 4x4 is not an option...
| Mason | | | |
by Moots1288 » Sun May 01, 2016 12:01 pm
It does not permanently put you in 4x4, I would go with the awd sleeve.
by DirtyBacon04 » Sun May 01, 2016 12:02 pm
Awd sleeve. No question.
Your 4x4 is still selectable. All this does is lock your right side CV to your I shaft. The selectability is in your xfer case, not disco.
by mason10198 » Sun May 01, 2016 12:13 pm
Okay, awesome. Thanks! I'll start looking. Is there a best place to get one?
Found it's GM part #12471636
| Mason | | | |
by mason10198 » Sun May 01, 2016 12:19 pm
Wait... Can't I just buy an AWD disconnect and bolt it on?
| Mason | | | |
by jdmser » Sun May 01, 2016 12:48 pm
You'll get a service 4x4 light
jdmser
by DirtyBacon04 » Sun May 01, 2016 1:13 pm
Not necessarily. If you leave the actuator plugged it, and just zip tie it up out of the way, the light won't come on. Or you could do like me and just believe with everything you are that some day... some day that friggin light will burn out
by mason10198 » Sun May 01, 2016 3:38 pm
I think I'm about to buy the "improved" AWD unit from US powertrain on eBay. I don't want to get stranded again because of another shift fork shearing.
Sent from Tapatalk
| Mason | | | |
by mason10198 » Sun May 01, 2016 3:48 pm
So if I DO use this AWD disconnect, the front wheels WON'T still be locked together in 2wd mode, and it WON'T hop when turning, correct?
Sent from Tapatalk
| Mason | | | |
by v7guy » Sun May 01, 2016 7:51 pm
No, the wheels won't be locked together, because you have this nifty thing called a differential that allows the wheels to turn at different speeds
by mason10198 » Sun May 01, 2016 8:06 pm
I know that... Was just making absolutely sure because I don't feel like spending 200+ bucks on something that won't work for me.
Sent from Tapatalk
| Mason | | | |
by DirtyBacon04 » Sun May 01, 2016 8:35 pm
US Powertrain makes a great product. You won't be disappointed
by mason10198 » Sun May 01, 2016 8:39 pm
| Mason | | | |
by v7guy » Sun May 01, 2016 8:43 pm
by DirtyBacon04 » Sun May 01, 2016 9:17 pm
I've got it in the Baconmobile
by v7guy » Sun May 01, 2016 9:45 pm
I wanna say Kyle is running one too, but I could be mistaken... It happens frequently enough lol
by Trail X » Mon May 02, 2016 4:54 pm
Mason, dude, you gotta turn down the dramatics a bit! :facepalm:
by Jrgunn5150 » Mon May 02, 2016 6:01 pm
I also have the US Powertrain unit, it has been working fine for about 8 month's now, and actually has the AWD part's inside.
by TBYODA » Tue May 03, 2016 12:13 am
Mason be like me and red neck it! :lol: :lol:
by mason10198 » Tue May 03, 2016 12:35 am
| Mason | | | |
