by Cable810 » Tue Mar 29, 2016 11:16 pm
[quote="v7guy
Really the side of the frame where the shock hoop mounts should have a reinforcement plate on it through there and if you wanna be extra paranoid, slap a taco gusset between the tube and the side of the frame up to the top so that it can't bend in because it'd be compressing the taco gusset.
It looks like it flexed the thin metal of the frame until it work hardened and cracked, ultimately breaking off around the perimeter of the weld.
I believe he just slapped a square plate over the hole and then welded it back on.
Hell, I may have typed this all up before LOL I know I at least thought about typing it, meh, if nothing else, here it is again. Hahaha[/quote]
Thats what I did to fix it. It was a combination of a bad weld and no hoop support that led to failure!
