by v7guy » Tue Mar 08, 2016 1:01 am
I assume it's a result of welding a small tube to the side of the frame and the whole shock mount acting like a big lever arm flexing the thin metal of the frame over and over at the weld until it broke the metal that was probably made more brittle by the HAZ of the weld.
Just an example of why you should plate the frame.
Hopefully there's now rather generous reinforcement plates on both sides to remedy it. Might wanna taco gusset it if there's room... I've seen plenty of setups with out em though.
