by DirtyBacon04 » Wed Dec 23, 2015 1:23 am
I could totally see myself hanging my dry cleaning from your bumper loop...
Just Kidding...
I dont get anything dry cleaned
by Anthony Hernandez » Wed Dec 23, 2015 2:09 am
Well I hung yours....and your moms today..... And still found time to not give a fuk.... Just sayin...
by Rickalicka18 » Wed Dec 23, 2015 9:39 am
Shots fired :shoot:
Rickalicka18
by DirtyBacon04 » Wed Dec 23, 2015 11:06 am
damn it. i hate non-consensual clothes hanging... especially across 2 generations.
You've won this one Mr. Hernandez, but i'll be baaaccccckkkkkkkk
by Anthony Hernandez » Wed Dec 23, 2015 1:44 pm
Hahahaha... That is kind of weird once I thought about it a little.
by HeavyChevy4200 » Thu Dec 24, 2015 7:17 pm
Worked on this.
HeavyChevy4200
by M_C_U_02 » Fri Dec 25, 2015 12:07 am
Just discovered the same problem on mine while doing ball joints.... :facepalm: My axle was flopping around when I had everything apart, so I popped it out and the bearings spit their guts... probably also why my 4wd selector would randomly flash every now and then.
It's a pretty pricey part... I'm not above hitting up junk yards for parts, but this disconnect housing seems to be a common problem; which makes me want to go new.... ~$450. MERRY CHRISTMAS!!!! :drool:
M_C_U_02
by HeavyChevy4200 » Fri Dec 25, 2015 12:07 pm
M_C_U_02 wrote:Just discovered the same problem on mine while doing ball joints.... :facepalm: My axle was flopping around when I had everything apart, so I popped it out and the bearings spit their guts... probably also why my 4wd selector would randomly flash every now and then.
I followed the Tech Doc on here and rebuilt mine. Wasn't all too bad to do and only cost me $85 in parts. That's including the 35mm axle socket.
Sent from my SM-T310 using Tapatalk
HeavyChevy4200
by TBYODA » Fri Dec 25, 2015 1:13 pm
You guys need to look around more and read posts and save links. Kyle first posted these eBay adds awhile back and I would suggest the AWD version.
http://www.ebay.com/bhp/trailblazer-axle?rmvSB=true
by M_C_U_02 » Fri Dec 25, 2015 10:29 pm
Much appreciated TBYODA n HeavyChevy4200... Looking into it now.
M_C_U_02
by Rickalicka18 » Fri Jan 08, 2016 8:10 am
Just installed a scanguage II and leds for my fog lights. Got to clear my codes, although I keep getting a P0449 code... Have cleared it 4 times and it keeps popping up. But I love all the features of this thing. Especially the code clearing function
Rickalicka18
by DirtyBacon04 » Fri Jan 08, 2016 9:00 am
Productive two days for me! Replaced the thermostat and coolant temp sender that I've had on hand for a few years... and replaced the front wheel hubs with ACDelco units. It's like driving on grease! So smooooooth. I didn't realize how much of the noise and occasional clunking was coming from the hubs.
Now for this daggon' fuel pressure regulator.
by Moots1288 » Fri Jan 08, 2016 7:31 pm
I might need hubs too
by bspellman » Fri Jan 08, 2016 8:43 pm
Been a while since I posted anything. It is in pieces lol
bspellman
by HeavyChevy4200 » Sat Jan 09, 2016 11:57 pm
Changed the front brakes and upgraded to larger rotors.
HeavyChevy4200
by Cable810 » Sun Jan 10, 2016 12:02 am
First fire up in over a year!! I'm getting there!! :woot:
by Cable810 » Sun Jan 10, 2016 8:56 pm
Steering is 100% bled!!!
by Trail X » Mon Jan 11, 2016 12:11 am
bspellman wrote:Been a while since I posted anything. It is in pieces lol
Whoah, what are you working on good sir?
by v7guy » Mon Jan 11, 2016 10:50 am
Maybe that 5.3 swap he was debating awhile back? LOL
Brakes look nice Andy!
Calebs going to be finished before me at this rate LOL
by KingBird » Tue Jan 12, 2016 12:20 am
Woman gave me two Autofeel 30watt LED spot pods for Christmas. I finally got around to adding them to the center of my light bar tonight and I got them aimed. So, as it stands now, I've got two flood 18 watt LED pods, two 18 watt LED spots, and the two 30 watt LED spot pods dead center.
:flex dirty:
Edit: Took an early morning pic.
KingBird
