by HARDTRAILZ » Wed Nov 18, 2015 2:04 pm
Why? Pretty sure with that setup it would be a quite unneeded expense.
I would think those axles and 203-205 would be plenty of kicking... :cheers:
by KingBird » Wed Nov 18, 2015 6:07 pm
Wretched excess. Like the guy in VA Beach that put a supercharger on his viper. You gotta admit that it would be funny to tell the jeep guys that you'll climb the giant rock at idle...
KingBird
by M_C_U_02 » Mon Nov 30, 2015 10:21 pm
Envoy bezel... Cadillac needles. It definitely tightened up the instrument cluster.
Looking to get white L.E.D.s and transparent blue lens/plastic/tape to illuminate numbers and increment marks (while leaving red warning marks red, and the needles and gauge labels bright white; i.e. RPM, speedo, fuel, temp, etc.)... Bought the blue L.E.D.s but will probably muddle the colored marks....
[img]
[/img]
[img]
[/img]
[img]
[/img]
New bezel and needles; car on.
Envoy bezel and Escalade needles
Original needles and bezel
M_C_U_02
by moose1 » Mon Nov 30, 2015 10:33 pm
beats the hell out of my plans for electrical tape to hide the tire pressure warning light. way to go, looks good.
moose1
by HeavyChevy4200 » Sun Dec 06, 2015 7:23 pm
Lots of wrenching.
Took off the brush guard to install Trailblazer tow hooks. Envoys never came with tow hooks from the factory had to get creative. First the bumper cover didn't clear the hooks. Trimmed the bumper. It was still going to be to much of a pain to get a recovery strap in there. Flipped the tow hooks from left to right. Now it's manageable to get a loop in through the bumper cover slit.
Also adjusted the hand brake. It's never worked since I bought the Envoy in April. Found out the brake pads were almost at the wear indicators so a run to the parts store was in order. Once I got everything back together I realized I adjusted the driver side a smidge too tight. It was making lots of noise going down the road. Tore it all back down and readjusted it. It was only a quarter turn too tight. Bah!
Good hand brake, good rear brakes and now I have front recovery points. Ready for the offroad park later this month.
HeavyChevy4200
by mason10198 » Mon Dec 07, 2015 10:46 am
Spent all weekend out in the garage getting ready for the bigger tires. Installed new trans cooler and replaced upper and lower ball joints on the frontend. Trans cooler was straightforward, but ball joints took some effort.
Ended up tearing a couple holes in my driver side CV boot because I didn't have my axle nut to release it from the spindle, but since it was still under warranty I just ran it back to Oreillys and they gave me a new shaft free of charge.
Got all that done, then saw the radiator leak. It's not coming from the actual fins, but from all around the edge where the bottom tank clamps to the metal. Not much I could do so I dumped in some Alumaseal and drove around for a few minutes. Hopefully that will seal it up good enough.
by escapepilot » Mon Dec 07, 2015 5:49 pm
Today??...damn on board air project has been taking WAY too long to work out. Almost done and a new leak...in a fairly inaccessible place.
But at least the new DVD head unit is in w/ a back up cam.
escapepilot
by M_C_U_02 » Mon Dec 07, 2015 9:22 pm
Out with the old...
[img]
[/img]
In with the new
[img]
[/img]
3.5" suspension/spring lift
[img]
[/img]
Lifted '02 LS vs. stock '06 LT
[img]
[/img]
Alright so it was yesterday....
Ran out of daylight to do the remaining 3 of 4 ball joints... one was too bad to let go down the road so I hammered one in... gotta get the right tools
Out with the old...
In with the new!!!
3.5" suspension/spring lift (Liftmeister 2.5" lift: #83 to #87 up front / Tahoe springs in rear)
M_C_U_02
by Mirage » Tue Dec 08, 2015 9:31 am
New upper ball joints and Bilsteins up front.
Also got rid of the garbage can. No tip yet
Trying to decide on rear or side exit.
I do like the different sound.
Mirage
by M_C_U_02 » Wed Dec 09, 2015 12:45 am
Nice! Trying to plan out the exhaust myself.... I'm thinking side exit. Looking forward to seeing what you come up with...
M_C_U_02
by v7guy » Wed Dec 09, 2015 1:10 am
James, those Caddy needles look nice, I dig it! Lots of people getting shit done!
by Jrgunn5150 » Wed Dec 09, 2015 4:37 am
I changed relays 45&46 in the parking lot of my new job after I got a jump from the vice president on my first day of work lol.
I swapped to 9012 low beams last week, not sure if it's related or not.
by Aries » Thu Dec 10, 2015 5:17 pm
Trailered home my replacement. 2002 LS Trailblazer, I pretty much got it for a steel. Needs a transmission (which I have out of my roll over) and the 4x4 switch won't light up, I can't even hear any clicking when I turn the switch. I had to but a battery in it, I will do all new brakes and all the fluids will have to be flushed but for what I paid it's all about :woot:
Aries
by navigator » Thu Dec 10, 2015 7:12 pm
Aries from the pics in your build thread just nice to know you walked away. Good luck on your next build!
by Aries » Fri Dec 11, 2015 6:58 pm
Started to do my brakes when I realized the pads looked new so I flushed the brake fluid and called it good. Then I ran over to DMV for an inspection and a two year tag. It drives good, just doesn't have reverse.
Aries
by DirtyBacon04 » Fri Dec 11, 2015 8:20 pm
Hey Cory, please tell me there was a wire or something holding the weight of that spindle... looks like the weight of everything is on your brake line. it made me cringe when i saw it
by Mirage » Sat Dec 12, 2015 12:46 am
DirtyBacon04 wrote:Hey Cory, please tell me there was a wire or something holding the weight of that spindle... looks like the weight of everything is on your brake line. it made me cringe when i saw it
Yes it was tied up with a bungee cord
Mirage
by Jrgunn5150 » Sat Dec 12, 2015 3:09 am
Aries wrote:Trailered home my replacement. 2002 LS Trailblazer, I pretty much got it for a steel. Needs a transmission (which I have out of my roll over) and the 4x4 switch won't light up, I can't even hear any clicking when I turn the switch. I had to but a battery in it, I will do all new brakes and all the fluids will have to be flushed but for what I paid it's all about :woot:
Congrats! I know mine has really grown on me lol.
by DirtyBacon04 » Sat Dec 12, 2015 6:18 am
phew, good to know. :safe:
well done
by KingBird » Sat Dec 12, 2015 10:48 pm
Today I addressed a few issues that I've been having. I pulled the front fascia and bumper off the truck and found a few things that needed attention. A few weeks back, I hit the front end kinda hard into the side of a barditch as I slid down into it in the mud. Since then I've had an annoying flapping noise at highway speeds and my cornering light was loose on the passenger side.
I fixed the flapping by zip-tieing the inner fender well back to the metal bumper. The reason the cornering light was loose was because the plastic mounting block that holds the corner of the bumper to the fender "peg" had broke loose. I expoxied that back to the bumper with "Plastic Weld" by JB Weld.
It's good stuff, just be sure to clamp the pieces together tightly for three hours.
KingBird
