by mason10198 » Sun Oct 25, 2015 1:24 am
Just installed 2 new wide beam HID spotlights. Thank you Michael (thehungrigerman) for one of them. the second was purchased from Amazon. I drilled a hole through the OEM crossbar and bolted them there. they feel pretty sturdy, but we'll see!
| Mason | | | |
by escapepilot » Mon Oct 26, 2015 12:44 pm
Removed the factory 12V cigarette lighter yesterday and installed a dual USB charger outlet. Should have been a quick, easy change over, but not with my TB... After replacing the outlet and connecting it up, I discovered I didn't have power to it. The other two had power. Hmmm. Auxiliary power fuse was good. Decided to check the cigarette lighter fuse under the hood and yup, blown. One new fuse, and it's now good to go. Why on earth did GM put separate fuses with different names in two different fuse boxes!
escapepilot
by Trail X » Mon Oct 26, 2015 5:02 pm
by Chango » Mon Oct 26, 2015 7:30 pm
Chango
by djthumper » Mon Oct 26, 2015 7:44 pm
by maricard » Mon Oct 26, 2015 8:23 pm
Ludwig Mies van der Rohe
maricard
by Rickalicka18 » Mon Oct 26, 2015 9:55 pm
Rickalicka18
by KingBird » Tue Oct 27, 2015 7:50 pm
If anyone has been keeping up with my ongoing saga, I got to thinking, a few weeks back, we had to replace the fuel pump. Since I needed the truck that afternoon, I replaced it with a Precision pump from O'Reilly...
That was my first mistake.
Then I started troubleshooting a problem that, with a little thinking, would have been solved very quickly. As a refresher, my issue has been a slight stumble at light throttle that evolved into a low speed stall that only happened when the vehicle was warm.
Anyway, I replaced the Precision unit with an OEM Bosch (what came out of it). I took it out this evening, ran her up close to triple digits and got her good and warm. I still had the stumble at light throttle but no stalling.
But wait, there's more! I received a package from North Carolina today as well, so I replaced my ECM with their loaner which obviously has a bit of an update because now the stumble is gone too! I'm going to put all of this in a build thread, I just wanted to update.
KingBird
by ErikSS » Tue Oct 27, 2015 8:07 pm
I'm glad to hear your problem is resolved Brian! Do you think the programming would have fixed the problem or was it both the pump and program?
by KingBird » Tue Oct 27, 2015 10:24 pm
I think the stalling was the crappy pump, the stumble was the ECM, it had that immediately after the engine swap.
KingBird
by v7guy » Tue Oct 27, 2015 11:49 pm
I've been down the bum replacement pump route before, not fun.
Marc, looks like you made it through the manifold swap relatively unscathed! Congrats!
by KingBird » Wed Oct 28, 2015 9:09 am
I should have known better.
KingBird
by v7guy » Wed Oct 28, 2015 1:04 pm
by Trail X » Thu Oct 29, 2015 10:08 pm
Keep an eye on it Brian. The ecms trim their variables over time, they tend to run very liberally at first and attempt to hone in on perfect combustion over time. Your new ecm has no history, so it's probably running rich. This is the same joke about the dealer ecm tune, where all they do is erase the ecm trim history and all the sudden your car starts running better. Not saying that this isn't fixed, just that I'm skeptical of magic ecm fixes.
by KingBird » Fri Oct 30, 2015 12:41 am
Will do, thanks for the heads up. I just drove it 300 miles to the mountains. What you're saying explains why it was getting such horrible gas mileage the last couple of days. Unplugged the stock ECM at 18-20 highway, and plugged in the loaner ECM to get 14-17 highway... :scratch:
I was wondering what the deal was.
KingBird
by TB2004EXT » Mon Nov 02, 2015 1:00 am
Just baught some rustoleum rust preventative to slow down the process until i can find a whole new door.
TB2004EXT
DriveTrain: AWD
by moose1 » Sat Nov 07, 2015 9:40 pm
Got some maintenance items out of the way before winter and clear up the front vibe.
First i joined the disco rebuild club and you guys made it sound much more fun than it was.
replaced a leaking front diff seal.
replaced both cv axle,hubs and passenger side UBJ. changed front diff, engine, and tc fluids.
took me a couple days but well worth it.
moose1
by Trail X » Sun Nov 08, 2015 11:34 am
Looks like you had a lot of fun. Always makes you feel good when your truck is running smooth again. Congrats on doing all the work yourself.
by moose1 » Sun Nov 08, 2015 9:24 pm
Thanks, i always try to weigh the cost/time/tools aspect of repairs. i'm a hobby mechanic so some repairs i just don't have all the tools, had to borrow a BJ press. but it is ready for the snow. Bring it on!
moose1
by HARDTRAILZ » Sun Nov 08, 2015 9:44 pm
I always borrow the parts store press but it is a nice feeling when it all comes together.
