by bilit66 » Tue Oct 11, 2016 1:38 pm
I assume you were running the factory 18x8 with a 50 mm offset and a 1.5" inspacer. This should be enough offset to run a 32x11. Ball joint clearance should be close but clear. What did you end up doing?
06 Denali XL
MarkMC 2 1/2" Suspension Lift, MarkMC 3" Body Lift
Beilstein HD's in the Front, BDS 55619 Lift Kit Shocks in the Rear, 32x11 No Spacers
