Long travel IFS
by v7guy » Tue May 19, 2015 12:57 am
Been working on this for a long while and it's starting to look like it's getting somewhat close to being done sometime this summer. Even after it's driveable I figure there'll likely be small things that need sorted out.
Essentially I've taken a mixture of 3500/2500HD parts and tossed em on the trailblazer.
The front diff from the 3500 wouldn't fit in the stock subframe, additionally it couldn't be kept at a reasonable height if I centered it even with a rear sump pan, so I used it in the stock configuration and tossed some 5.13s in it. With 37s it should act about like a stock trailblazer with 4.10s
remove subframe, drop oil pan
need some lights for the UFO
stock oil pickup won't work with rear sump
cobbled together a new pickup from a colorado I5
rear sump pan
then the front diff was put up in place to see where it would fit, the first of many many many times it would go in and come out
by v7guy » Tue May 19, 2015 1:05 am
a mix of some of the parts going in this thing.
lower a arm heim joint misalignment spacer
2014-02-19 (1).jpg (17 KiB) Viewed 35787 times
uniball cup that'll replace the balljoint
14 bolt rear axle from a 2500HD silverado
37" humvee wheels and tires
2014-04-10 (1).jpg (12.9 KiB) Viewed 35787 times
misc heim joints
by v7guy » Tue May 19, 2015 1:24 am
regearing the front diff was a bit problematic due to the short side stub shaft not wanting to come out. Moots and I tried for hours to get it out and it just wouldn't budge. After a little reading it turns out it's notorious for being impossible to remove and GM has a service bulletin telling the service techs to cut it off. Which in the end is what we ended up doing. In the process we did develop the infamous stub shaft twerk.
Eventually I got the wheels powdercoated, assembled them with James02, and aired them up without issue, tossed some airsoft beads in em for balance. Bent up some subframe tubes, made some diff brackets for the front diff and the rear axle too. Ended up using some brake lines from a 3500 silverado with a 6" lift and adapted them to the trailblazer lines.
big ole pinion
brackets and brackets
powdercoat
subframe tubes
subframe tubes
subframe tubes in
PHR bracket
PHR bracket
axle in and brake lines ran
by v7guy » Tue May 19, 2015 1:35 am
There wasn't anything I could find that would fit the design, so I ended up building my own spindles that let a 3500 hub bolt to it.
parts
bolted together
2014-09-26 (1).jpg (13.64 KiB) Viewed 35786 times
clearance
by v7guy » Tue May 19, 2015 1:43 am
From there the frame needed plated and some shock towers needed to be built.
2015-01-02 (2).jpg (13.02 KiB) Viewed 35786 times
2014-12-31 (1).jpg (17.2 KiB) Viewed 35786 times
by v7guy » Tue May 19, 2015 1:52 am
Front diff bolted in, steering rack roughly in place and a few misc pics
by bartonmd » Tue May 19, 2015 6:50 am
Coming right along!
by HARDTRAILZ » Tue May 19, 2015 9:07 am
Atta boy! Well done! Good things come to those that wait.
by Trail X » Tue May 19, 2015 11:25 am
You are a crazy person!
Hey, when am I going to see this at TECORE?
Is the final picture the planned resting height of this thing?
by v7guy » Tue May 19, 2015 3:35 pm
I've gotta find some springs to drop the ass end a bit or buy some coilovers... probably shoulda done coilovers from the get go. At the highest point (hi lift on the roof basket) it's about 7' 8", I think I can get it real close to 7'. There's already a few items I would do differently if I were to tackle this again. But that's kinda the case with any build I think.
Appearance at TECORE? Eh, absolute earliest would be in the fall. At my current pace I'm doing pretty good, if overtime gets stupid again and I go back to 90 hour work weeks who knows. I'd like to be daily driving it for a few weeks before I try any real trips with it.
by tarsh » Tue May 19, 2015 7:55 pm
Wow, is all I have to say... Wow... Ur crazy Jason. But I do plan to do the same..ish at some point as well. U got skillz brutha. Can't wait to see a finished product of sorts
Take the path less traveled
tarsh
Name: Nathan Schroeder
by Eredin » Tue May 19, 2015 7:58 pm
Wow, that's insane, but nicely done. Looking forward to the results, great work!
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
by maricard » Tue May 19, 2015 8:12 pm
Great project!
_____LESS IS MORE_____
Ludwig Mies van der Rohe
maricard
by Opeth » Tue May 19, 2015 10:07 pm
Wow... Simply awesome
by ErikSS » Thu May 21, 2015 6:55 pm
ok, with all these positive comments... knowing Jason as well as I do... and knowing how long he's been working on it... Dude, once it drives I'll be impressed. lol So far you're just insane! :-)
by Moots1288 » Thu May 21, 2015 7:43 pm
Ok, as close me and Jason are... this is awesome but he still sucks
by Regulator1175 » Sat May 23, 2015 12:24 am
Ehh, I will give you $500 for it.
by v7guy » Sat May 23, 2015 2:51 pm
Meh, it's probably not even worth that Matt, especially after it falls apart LOL
Got an order in from ruffstuff today for some of my missing parts, that's exciting.
by v7guy » Tue May 26, 2015 10:34 pm
Got some time to start working on the upper A arm brackets, lil spacer put next to the misalignments to make sure it stays wide enough after welding. Also had an epiphany that I could use a hole saw to cut the rounded space for the rod end, dunno why it never occurred to me before. Looking forward to welding em on the frame tomorrow.
by Trail X » Tue May 26, 2015 10:51 pm
Nice stress transition with that hole saw cutout. Shouldn't see any stress concentrators there. Out of curiosity, what grade steel are you using? Assume you're using 70ksi welding wire?
