Custom rear spare carrier - swing arm
by maricard » Mon May 04, 2015 6:43 pm
This is it!
After several hours to think about it, I build my swing arm for my spare tire of my dream.
I took some picture to show how I build it.
If you have any question feel free to ask me.
I'm not really good in english but I'll do my best.
_____LESS IS MORE_____
Ludwig Mies van der Rohe
maricard
by maricard » Mon May 04, 2015 7:09 pm
I forgot to say thank to Karo for the idea!! :)
maricard
by Eredin » Mon May 04, 2015 8:26 pm
This is fantastic! I'm trying to figure out how I want to do mine, I have most of the metal and the spindle in hand. I like the latch design, I think that'll work better than the flat pull latch that I have.
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
by maricard » Mon May 04, 2015 8:36 pm
thank Caleb, if you have any question feel free to ask me.
maricard
by bartonmd » Mon May 04, 2015 9:00 pm
Looks good!
by v7guy » Tue May 05, 2015 12:25 am
It does look really nice, I dig it.
by Trail X » Tue May 05, 2015 2:05 pm
Very slick design. How is the flex when the carrier is open? and do you have anything that prevents the tire from swinging around and hitting the side of the vehicle, or hold it against gravity? After a few uses, I'm betting you'll be wanting one.
by maricard » Tue May 05, 2015 2:41 pm
Trail X wrote:Very slick design. How is the flex when the carrier is open? and do you have anything that prevents the tire from swinging around and hitting the side of the vehicle, or hold it against gravity? After a few uses, I'm betting you'll be wanting one.
Without tire I had no flex. With tire I have 3\8" flex but it's not really a problem. And you're right I'm looking for a universel damper. At this time gravity help me but when it's windy or in a trail it's not easy to use.
Someone know which damper use? I never use this before...
maricard
by Eredin » Tue May 05, 2015 3:31 pm
Where did you get the rubber isolator at?
Eredin
by Trail X » Tue May 05, 2015 3:49 pm
Marc, I used a standard automotive air extension spring (commonly used to hold up tail gates). You just have to find mounting points that work for you, find the approximate length you need, then make it happen. Mine folds up when the tail gate is closed, and acts to close the gate. Your geometry may be different based on how yours is mounted, etc.
by maricard » Tue May 05, 2015 5:05 pm
Eredin wrote:Where did you get the rubber isolator at?
I bought it at EMS offroad store.
http://www.emsoffroad.com/store/index.p ... ts_id=4187
maricard
by Opeth » Tue May 05, 2015 7:16 pm
I like it!
by maricard » Fri May 08, 2015 4:06 pm
I had a old damper from the rear glass door of my rig in my workshop so I decided to use it.
It work very well.
It fit just fine and really close of the tailgate.
Thank to James for his help.
maricard
by BC backroader » Fri May 08, 2015 10:46 pm
You do nice work, Marc. I like it.
by Ole Blue » Sat May 09, 2015 6:27 pm
Nice!
Ole Blue
by djthumper » Sun May 10, 2015 12:11 am
Very nicely done.
by Eredin » Sun May 10, 2015 11:55 am
Want to thank you for all the pics. Stated building mine last night, based off your design.
Eredin
by Trail X » Mon May 11, 2015 11:56 am
maricard wrote:I had a old damper from the rear glass door of my rig in my workshop so I decided to use it.
It work very well.
I like that your rod is longer than mine, mine has difficulty sometimes holding the arm open on side slopes due to the really short lever arm.
by Moots1288 » Mon May 11, 2015 10:38 pm
You like his long rod
by Trail X » Tue May 12, 2015 9:25 am
:finger:
Return to Fab Work
