2002 on one tons
by Fastonthetrack » Fri Mar 20, 2015 10:22 pm
heres my 02 TB on one ton running gear. Dana60 front 14 bolt rear with 5.38 gears and spools. She sits up on 52" ford 1/2 ton leaf springs front and rear and 39.5 iroks. all stock drive train. running a toyota IFS steering box and rock ram hydro ram for assist and 14" bilsteins.
Fastonthetrack
by Cable810 » Fri Mar 20, 2015 10:50 pm
2002 seems to be pretty popular for SAS :lol: Looks good man!
by Fastonthetrack » Sat Mar 21, 2015 1:41 am
Thanks dude. still some work to iron out.
Fastonthetrack
by navigator » Sat Mar 21, 2015 9:00 am
yeah, nice looking ride!
by v7guy » Sat Mar 21, 2015 10:40 am
looks spiffy! I dig it!
Why didn't you completely weld the steering box plate to the frame? What's up with the lack of weld on the pitman arm (looks like there needs to be a second bead ran on the top portion there)?
by Fastonthetrack » Sun Mar 22, 2015 12:19 am
The steering box plate will be welded more when I clean up the frame. The pitman arm something I'm testing. So far so good.
Fastonthetrack
by HARDTRAILZ » Sun Mar 22, 2015 9:09 am
Looks like fun!
by ErikSS » Sun Mar 22, 2015 1:54 pm
Very nice~! If you had to guess, how much do you think the parts for this swap costed you?
by Jrgunn5150 » Sun Mar 22, 2015 6:47 pm
Awesome
by Fastonthetrack » Tue Mar 24, 2015 12:21 am
ErikSS wrote:Very nice~! If you had to guess, how much do you think the parts for this swap costed you?
I got this truck this way mostly.. ive done quite a few SAS builds.. if you can do the work yourself and know how to source parts and make deals, probably in the neighborhood of 5-7k after everything is said and done.
Fastonthetrack
by Trail X » Wed Mar 25, 2015 1:59 pm
How much lift does it have over stock? Looks higher than it needs to be. Looks like you could remove the spring blocks and likely be happier. What are your plans for something like this? Do you do mud bogging? Or are there some gnarly trails around you where you're not very concerned about the high center of gravity? Thanks for sharing, I want to see more!
by Fastonthetrack » Wed Mar 25, 2015 4:42 pm
Trail X wrote:How much lift does it have over stock? Looks higher than it needs to be. Looks like you could remove the spring blocks and likely be happier. What are your plans for something like this? Do you do mud bogging? Or are there some gnarly trails around you where you're not very concerned about the high center of gravity? Thanks for sharing, I want to see more!
Your concerns are the same as mine. I plan on lowering the truck 3" or so but still needs to clear and stuff 39.5s. I will bump it out as well. Here the trails are very very off camber but more times than not have something to lean on. No open trails for us. Plan is for road and trail use. The leaf springs are brand new and most likely soften up and I'll lose some altitude that way. Another concern is the oil pan clearance with the dana 60. The reason for the blocks now is to address pinion angle and perch alignment I am rotating the axle tubes soon to rid all of these issues. I am going to raise the shackles possibly.
Fastonthetrack
by DirtRidinZ71 » Fri Mar 27, 2015 9:27 pm
Looks great! I have a few questions.
36" spring pad width d60?
How does the 4.2 like the 39.5 tires with 5.38 gears?
What t case are you running?
Do you have a pic of the oil pan clearance? Would pushing the axle more forward help? I have a 79 ford d60 so the diff is not offset as far.
What did you use for a steering shaft from the gear box to the factory shaft? Any pics?
I have been wanting to tear apart my 92 gmc truck and build a new family wheeler and set up about identical to this. With 39.5 irocs, 5.38 gears in a 79 ford d60 and 10.25 sterling, gm 52" front springs and 63" rear springs.
DirtRidinZ71
by Cable810 » Fri Mar 27, 2015 10:17 pm
He used the stock tcase and has a 241 ready to go in. He build looks a lot like what Steve and mike did.
by Fastonthetrack » Sun Mar 29, 2015 11:19 pm
DirtRidinZ71 wrote:Looks great! I have a few questions.
Theres not a ton of clearance for the oil pan, but if you bump stop it properly you shouldnt have any issues. The 4.2 doesn't really mind the gears and tires.. getting about 13mpg and it had no issue getting around..
I have an NP241 that im waiting on an adapter for to install.
Fastonthetrack
by Fastonthetrack » Sun Mar 29, 2015 11:22 pm
Oh and i am running a kingpin front end as well..
Fastonthetrack
by v7guy » Sun Mar 29, 2015 11:45 pm
How much compression would you gain with a rear sump pan?
I've always wondered how much it got in the way.
by Fastonthetrack » Mon Mar 30, 2015 12:01 am
well you dont ever want to put your leaf springs into a negative arch. soo if you bump stop them properly there is nothing to worry about either way.
Fastonthetrack
by Jrgunn5150 » Tue Mar 31, 2015 6:54 am
Fastonthetrack wrote:well you dont ever want to put your leaf springs into a negative arch. soo if you bump stop them properly there is nothing to worry about either way.
Negative arch isn't that bad, there's millions of 73-87 Fullsize Chevy's running around with negative arch. Flat packs are best, because you're not fighting against arch for articulation.
by ErikSS » Tue Mar 31, 2015 8:30 am
It sounds like this truck was built tall enough to not worry about the oil pan. Leaf springs have a reputation of loosing arch when compressed too far. They can, but you can replace or re-arch them also. They are generally not expensive.
