by navigator » Thu Mar 12, 2015 10:53 pm
by Trail X » Fri Mar 13, 2015 1:00 pm
Wow, those look bigger than 32.8".
by Cable810 » Fri Mar 13, 2015 2:27 pm
On Goodyear's website its says 33". They are a light tire for an Eply tire I think the 285 comes in at either 53lbs or 55lbs. I was considering them when I wanted to go to 33s...
by navigator » Fri Mar 13, 2015 3:36 pm
They were listed at 33.10 and 55lbs on the discount tire eBay listing. So far I have only had to pound that fender liner bolt a little. I figure I will put it through the motions and check the clearances when I install my front diff. I expect I will need to trim some fender liner etc but it doesn't appear I will need to trim any metal. The funny part is they fit my stock k1500 with no lift or trimming.
by Shdwdrgn » Sat Mar 14, 2015 1:29 am
I've been enjoying my reserved parking at work this week... :)
Someone plowed the parking lot over the weekend and pushed all the snow up against one line of decent parking spaces. Because I start later, I usually end up parking in back, but not this week! Myself and a few other made use of 4WD and have slowly beat down that pile through the week (not to mention the temps have been in the 60's). The first few days I plowed right into the pile, my tires sunk in a bit, and I gave my skid plate a bit of a workout. At least two days I left the truck parked with the weight of the front end resting on the skid, and when I looked today I can see no sign of any deflection in the plate. I was actually planning on adding side braces some day to attach to the mounting brackets where the WAAG pushbar was bolted, but now I'm not sure I need to.
Ah well, it was fun while it lasted, but I imagine the sun this weekend will finish off the pile, then I'll be parking in the back again.
Shdwdrgn
Contributing Author
by Eredin » Sun Mar 15, 2015 2:28 am
Dropped the rear sway bar out, had to cut the end links off, nuts are seized to the threads. I'll deal with getting the remainder out at a later time, if needed. Found that the N8030 shock bushings are looser than I thought so I need to figure out what to do to fix the bushing collar play. Discovered my lower pan hard bar now has some noise, bushing starting to get weak. Popped the front bumper cover out, snow mound pushed the corner in sometime last week, ready to get rid of it and build one from Mike. Passenger side CV is slinging grease out the end, so dropped a 4" worm clamp on it to see if that will resolve. Driver side isn't leaking yet, so leaving it be. Diff still leaking, but not bad. Still searching for 4.10 front/rear to swap in. Have some good buys on 8.6 rears that are close enough, but can't take a day off from new job for a few more weeks to go get them and the fronts don't seem to be too common. Also trying to figure out what I want to do for a spare tire carrier. I'd like a gate or a fold down, roof rack wrecks mileage to bad to warrant. Lots of stuff, hopefully more soon. Spring is here, itch to get out and work on stuff again has bit.
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
by Crotalus » Sun Mar 15, 2015 10:20 pm
Changed out original plugs and plug wires with new Delco iridiums and Delco wires. 1 lb of flesh from my knuckles and arms and 3.5 hours. Truck idles and runs so much better now. Just realized how dirty my engine bay is!
Crotalus
by HARDTRAILZ » Mon Mar 16, 2015 12:05 am
Drove it and loved every minute of it.
by afair88 » Mon Mar 16, 2015 12:32 am
I went and got a set of new bfg rough terrains for 450 super excited to mount tomorrow with my spacers from mark
afair88
by HARDTRAILZ » Mon Mar 16, 2015 8:38 am
by Jrgunn5150 » Mon Mar 16, 2015 9:12 am
by ErikSS » Mon Mar 16, 2015 9:29 am
The front plugs are not in the easiest place to reach on mine.
by Crotalus » Mon Mar 16, 2015 7:03 pm
Crotalus
by navigator » Mon Mar 16, 2015 7:19 pm
for my Suburban with the 5.3, I bought a plug boot puller, it helped a lot on the hard to reach ones. That might help for the TBs with the 5.3 as well.
by afair88 » Mon Mar 16, 2015 9:59 pm
afair88
by afair88 » Mon Mar 16, 2015 10:04 pm
:woot: Got my rubbers on finally!! Thanks for the lift and spacers mark!
afair88
by BC backroader » Mon Mar 16, 2015 11:05 pm
The tires and lift look great, afair88. Where did you find the BFGs for $450?
by afair88 » Mon Mar 16, 2015 11:11 pm
I found them on craigslist in stl he sales wholesale
afair88
by Trail X » Tue Mar 17, 2015 9:49 am
Failed inspection today for a myriad of issues, none actually affecting any sort of safe operation of the vehicle in my opinion.
by Eredin » Tue Mar 17, 2015 1:04 pm
Inspections would annihilate 50% of our states vehicles instantly, thank God we don't have them.
Eredin
