by TBYODA » Fri Feb 27, 2015 5:17 pm
CB antenna mounts similar to a firestick need the be made of metal and have a good ground back to the vehicle. That doesn't mean through the screws holding the mount and flat metal surface to metal surface is suggested. Other wise you are wasting you time and effort. CB radio/antenna install is NOT plug and play. I'd suggest some reading http://www.firestik.com/Tech_Docs.htm
by HARDTRAILZ » Fri Feb 27, 2015 5:40 pm
I plug n play w CB's. I am satisfied.
Magnet antenna and handheld unit was my go to for years.
by TBYODA » Fri Feb 27, 2015 5:54 pm
by 419TrailWisperer » Fri Feb 27, 2015 6:29 pm
419TrailWisperer
by HARDTRAILZ » Fri Feb 27, 2015 6:58 pm
by maricard » Sat Feb 28, 2015 11:45 pm
I finally received it.
Ludwig Mies van der Rohe
maricard
by v7guy » Sun Mar 01, 2015 1:33 am
That's exciting! How are you mounting it?
by maricard » Sun Mar 01, 2015 11:07 am
Well, first I asked to Mike for his steel bumper kit. But to ship it in Canada it's very expensive.
Now I'm looking to do it by myself. I was inspired by Mike's bumpers.
I will solicit bids and I'll see if the price are ok for me.
If it's not possible my last idea is to do like Karo did.
maricard
by KE7WOX » Mon Mar 02, 2015 12:48 pm
KE7WOX
by v7guy » Tue Mar 03, 2015 1:37 am
You wouldn't be the first person to not get the CV seated and have it work it's way out
by NC_IslandRunner » Tue Mar 03, 2015 6:51 am
I had that happen once in Georgia, just took a BFH and knocked it in until I heard it clip.
by Trail X » Tue Mar 03, 2015 9:53 am
I generally hear a difference in the sound of the hammer strikes when it gets seated. It becomes much more solid sounding once its fully seated.
by Cable810 » Tue Mar 03, 2015 10:46 am
I probably didn't seat it properly when I rebuilt it.
by BC backroader » Wed Mar 04, 2015 12:25 am
Had a shop install a new front hub for me today, while I was at work. The mechanic told me he replaced the one that was noisy on his stethoscope, but that the other should be done soon, as well. Sure enough, I can still hear a faint rumble from the front. He also spotted a wonky UBJ on the right, so I'll have to replace both when I get the lift installed. I'm trying to save for the lift, but the rear brake job on my K3500 and the new TB hub have eaten that money for this month, so the lift waits, again. :-(
by HARDTRAILZ » Wed Mar 04, 2015 12:45 am
Sucks you can't do it yourself. Hub is under $50 n hour to install.
by Eredin » Wed Mar 04, 2015 1:19 am
Yea, hubs are cake as long as the axle nut isn't sticky. You can generally rent the needed tools from a local parts store in the US, but may be different for you all.
Couldn't even total how many tens of thousands I've saved on doing my own work on stuff.
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
by TBYODA » Wed Mar 04, 2015 4:36 pm
I got new shoes today. Went with Mastercraft MXT 265/75r16. $766 out the door. They make very little noise on the road, much quieter than the Guard Dog. Then again anything is quieter than them. :lol:
by HARDTRAILZ » Wed Mar 04, 2015 4:42 pm
Nice upgrade!
All i did was drive mine to work cause the snow was coming in. Will give it a big drink of 93 on the way home.
by Cable810 » Wed Mar 04, 2015 5:02 pm
I wonder if the reason for the noise the Guard Dogs produce is cause they are retreads. UPS uses retreaded tires and they make some decent noise.
by TBYODA » Wed Mar 04, 2015 5:33 pm
