by Eredin » Sun Feb 22, 2015 2:38 am
Found that the disconnect actuator is junk, won't work under pressure and binds. I managed to get it to lock in long enough to get to the garage and tear it apart. After all the troubleshooting, we decided to throw in a 3/8" nut inside the disco and bolt the actuator back on to lock it in all the time. It's not ideal, but I don't have time to wait on a new one at the moment due to our weather. For now, I'll have to live with the 4WD Maint dash light.
We measured the extended length of the actuator and it came out to exactly 1/2" retracted vs open. However, when we found an item to match the needed length the actuator wouldn't seat completely. 3/8" ended up being our magic number and we found a nut to match the size. I'm sure others have done this before, but just a quick bit if someone needs it for a bind.
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
by Norcrosski » Sun Feb 22, 2015 8:05 am
Just plug actuator back up and zip tie to frame
Norcrosski
by Trail X » Sun Feb 22, 2015 10:08 am
Eredin wrote:Found that the disconnect actuator is junk, won't work under pressure and binds. I managed to get it to lock in long enough to get to the garage and tear it apart. After all the troubleshooting, we decided to throw in a 3/8" nut inside the disco and bolt the actuator back on to lock it in all the time. It's not ideal, but I don't have time to wait on a new one at the moment due to our weather. For now, I'll have to live with the 4WD Maint dash light.
Yep, I did that for a couple of years. It's been dubbed the "poor mans" awd sleeve.
by Cable810 » Wed Feb 25, 2015 3:43 pm
I started pulling the front lift off today... I think I figure out why my 4x4 wasn't working. I disconnect the upper control arm from the Upper BJ and when I let it down my cv shaft just came right out no effort required. I pushed it back in and now I cant pull it out. So I wonder if it worked its way out?
by galacticfuzz » Wed Feb 25, 2015 7:23 pm
Designed mounts for my lights yesterday. Finished up printing them today and installed them. Just need to run the little bit of wiring and then adjust them.
― Antonio Porchia
galacticfuzz
by v7guy » Thu Feb 26, 2015 11:37 am
started running brake lines and bolted up the calipers.
by HARDTRAILZ » Thu Feb 26, 2015 12:25 pm
Now you're cookin with gas! Nice!
by DirtyBacon04 » Thu Feb 26, 2015 3:47 pm
Since the last TECORE, I've been meaning to relocate my CB antenna because Yoda said it's likely to explode or something...
So I used a left over piece of superstrut and bolted it up to the roof rail so it sticks out the back left corner of the RTT. I angled the bar also so it wont snag on trees. It flexes a good bit, but has yet to loosen. I have the 4ft antenna on it, but I keep the 2' one in the back just in case the brush gets too heavy.
by TBYODA » Thu Feb 26, 2015 4:02 pm
DirtyBacon04 wrote:Since the last TECORE, I've been meaning to relocate my CB antenna because Yoda said it's likely to explode or something...
LOL not exactly the words I used. However you should get much better reception with more of the antenna above the roof. How's the SWR.
by DirtyBacon04 » Thu Feb 26, 2015 4:05 pm
i still don't have a meter...
by Eredin » Thu Feb 26, 2015 5:42 pm
I actually have my 3' attached to my rear bumper cover and grounded to the frame behind the tail light. Our trails are tight and low enough that I can't mount it higher without breaking or damaging it, even with the spring. My SWR is perfect, but my range isn't far. :(
Eredin
by 419TrailWisperer » Thu Feb 26, 2015 8:11 pm
Heard some squeaking coming form the front, and found the fan all over the place... time to replace the water pump.
Quick and easy fix.... except I got impatient and broke 2 bolts off in the block :facepalm:
at least I had a nice walk to Carquest, silver lining right?
419TrailWisperer
by Trail X » Thu Feb 26, 2015 11:35 pm
Cable810 wrote:I started pulling the front lift off today... I think I figure out why my 4x4 wasn't working. I disconnect the upper control arm from the Upper BJ and when I let it down my cv shaft just came right out no effort required. I pushed it back in and now I cant pull it out. So I wonder if it worked its way out?
Likely assembly error. C clips don't normally work themselves out. They are used on nearly every fwd car.
Looks like it's going to break off Any second!
419TrailWisperer wrote:Heard some squeaking coming form the front, and found the fan all over the place... time to replace the water pump.
How in the world did you break them off in the block? Mine came out real easy.
by DirtyBacon04 » Fri Feb 27, 2015 6:07 am
If this doesn't work I have another idea... if THAT doesn't work then... well, it's going to work
by v7guy » Fri Feb 27, 2015 6:51 am
Mike, an SWR meter makes a big big difference. Just screwing the tip of the firestick in and out a half inch made a huge difference in the ability to transmit and receive... Big big difference. Most of us at tecore had a hard time understanding you here and there. Spend the money and time, I like hearing your smart ass comments lol
by Trail X » Fri Feb 27, 2015 9:23 am
As it was, all we heard was:
BZZZZZRRZZZZZZZHHHZZZZZZZ-ounds-like-BZZR-bar-BRRZZZZZZ-ouling-BRZZZZZZ-CHHHH
by galacticfuzz » Fri Feb 27, 2015 12:20 pm
DirtyBacon04 wrote:If this doesn't work I have another idea... if THAT doesn't work then... well, it's going to work
Your mount gave me an idea. I made one in Inventor that I could print for you if you'd like to give it a try. Could have it print this afternoon and send it out to you after this weekend. It's slanted back at the antenna mounting point. I would just need to know the offset distance to clear the RTT tho. Here is an initial rendering. It'd be printed in black.
― Antonio Porchia
galacticfuzz
by DirtyBacon04 » Fri Feb 27, 2015 1:34 pm
I'm assuming it'd mount to the roof rails where mine is? I'd be concerned for plastic mount holding up with the twisting because of the leverage against it. Also, the offset will have to be rather large to clear the RTT. We're talking 5-6 inches
by galacticfuzz » Fri Feb 27, 2015 1:55 pm
Ah yeah, that would be too much of a lever against it. I know I've not had any issues with the mounts that I've made for my lightbar to the roof rails but I couldn't tell how far out that had to stick to clear. The twisting would be the weak point. I know I looked at running simulations upwards of 75-100lbs but that was with only a 3" standout.
― Antonio Porchia
galacticfuzz
by DirtyBacon04 » Fri Feb 27, 2015 2:05 pm
I'll keep you in mind though, in case i think of something else. nice to have someone with access to the 3D printer
