offroadTB.com • View topic - ***NEW PRODUCT - Massive GMT360 Adj Rr Suspension Parts***
Products offered by our vendor: Massive Speed
Moderator: K STYLEZ
by ErikSS » Thu Aug 15, 2013 4:32 pm
There is a big difference between 6mm and 0.07mm. I'm guessing the brackets bend easier than we think, or sometimes the bushings are harder to compress. All in all, looks like a nice product that is on my "someday when I'm rich" list. lol
by AlekG » Fri Aug 16, 2013 12:57 am
Glad to say my order is in. A very nice contact <Ingrid> helped me out tremendously as there are issues with shipping to Canada, in terms of costs and travel times.
I haven't had a US mail box address for quite some time but there are some services in Niagara Falls that will receive packages even without renting a mailbox. With the shipping being a flat $5 and the package fee of around $6, I cannot go wrong with this method. Sure, its a bit of a drive, but combining it with a Saturday outing will do the trick.
As for the measurement ... I got the inside length of the mount to be 2.265 inches with is 57.5 mm, which is spot on. So I will just have to make sure to tell my mechanic to PRESS those suckers nice and tight.
That's all for now, will be posting more in other sections in the coming days/weeks.
AlekG
AlekG
by Karo » Sun Sep 22, 2013 5:27 pm
Installed my set today, it went in with mostly no problems. But here is the story with some questions. The rear axle lower control arms are easy to replace. For removing the upper control arms I had to trim the inner fender plastic part to remove the front bolt. For the lower control arms I used the bolts delivered with the kit. Are there any specifications for tightening the bolts in this kit? I used the factory tightening specifications, is that okay?
How is it possible to tighten the securing nut in that position when the upper control arm is mounted? I mean if you wish to extend or adjust the arm it is not possible to loosen or to fasten that nut when the control arm is mounted. Are there any ideas or did you have to remove it, extend it and secure it and install it then back in?
I used the factory bolts and nuts for the upper control arms, as I had no chance to get on the nut in the frame for the front mounting bolt. So how will it be possible to remove the nut in the frame and use the bolt and the nut from the kit? The bolts from the kit didn´t even fit into the factory nuts, I have tried that way.
As I have my rear stabilizer bar installed with the stabilizer shaft I found out that when twisting the axle it will hit the upper control arms, is that correct?
If so okay so there is a reason now to remove the stabilizer bar. :)
The pan hard was a PITA to get in on the passenger side! The bushings haven´t getting in even if I had them compressed them in a parallel vise before. I had to extend the mounting point and I had to remove 1mm from the bushing and event then it was a pain. Finally it went in, but I think it never would get out. ;)
Drivers side was no problem:
I used the factory bolts for the pan hard as I didn´t had any idea to get the nut in position on the drivers side mounting point. It is much easier to use the factory nut and bolt as the factory nut has a extended part that the nut is stopping from twisting.
I really like the fact that I can easy adjust the pan hard now, wish I could do that in the same way easily with the upper control arms.
Overall I am happy with the product and the good quality! So massive did a really good job on that product!
Karsten
Karo
by ErikSS » Sun Sep 29, 2013 10:50 pm
Wow! Nice write up Karo! :cheers:
by Regulator1175 » Sun Oct 06, 2013 3:37 pm
First off, thank you for a great product and fast shipping!
I am having an installation issue with the panhard bar. I have upgraded to the 9.5" 14 bolt Trailblazer SS rear end. I have the axle pushed back 1.75" from stock and the panhard bar is making contact with the rear diff cover. The rear axle is lower then resting height in this picture, there is not any further up travel.
I am not sure if anyone has experienced this issue yet, but it looks like there needs to be some design modification for a work around.
by Trail X » Mon Oct 07, 2013 9:16 am
Your workaround is reducing the amount of axle stretch... :lurk:
by Regulator1175 » Mon Oct 07, 2013 10:41 am
by Trail X » Mon Oct 07, 2013 11:33 am
Not to second guess your decision, but do you really need 1.75" of stretch? I thought you could basically stuff 35s with only ~1/2" of extra stretch.
Another thought, not that it's ideal, but can you put your purple rod spacers both on one side of the rod end? That would essentially offset the whole panhard by an extra inch or so.
I don't think that bending the panhard would really be a good option for you (it was the first thing that came to my mind), only because that bar rotates to adjust. Otherwise, that could work.
by Regulator1175 » Mon Oct 07, 2013 11:56 am
by Karo » Mon Oct 07, 2013 4:34 pm
I saw Karl has responded to your question in the other thread so I hope everything clears out!
Karl I would remind you to hopefully answer my 6 questions in THIS Thread. The kit was not delivered with some install instructions so there are open questions and the answers are maybe interesting for other customers, not only for me.
Thank you
Karsten
Karo
by ErikSS » Mon Oct 07, 2013 8:31 pm
Karl, do you have many SS trucks running these arms?
by JoeyV » Sat Sep 20, 2014 12:36 am
Now that I have started to work on my build, there are some concerns with the Massive pan hard bar that I purchased a few months back for my '02 Trailblazer. First, the neoprene boots that everyone else received with their purchase, said to be standard now, was not standard with my purchase. Second, both sets of the included aluminum bushings are at a minimum of 4 mm too big for my passenger side mount/bracket. It will work fine for the driver's side as that bracket is bigger and so is the original sleeve bushing that is in the OEM pan hard bar. Finally, there is no compressing these solid aluminum bushings any further than they will butt together. See pics below
No neoprene boots.
Measured at the ends of the sleeve bushing mounted in the passenger's side of the OEM pan hard bar.
Driver's side of OEM pan hard bar.
Loose Massive bushings, compressed with hand strength.
The other Massive bushings, still zip tied in place but compressed by my vice with as much torque as I could crank down on it.
JoeyV
by K STYLEZ » Tue Sep 23, 2014 12:14 pm
PM'd you JoeyV!!!
K STYLEZ
by Ole Blue » Sat Jan 24, 2015 4:50 pm
I know this is an old subject, but are these difficult to install and adjust correctly?
Ole Blue
by ErikSS » Sat Jan 24, 2015 11:01 pm
I've never installed a set of these. I've never heard anyone complain about adjusting them. I've had a set in my hands. They DO feel like great quality. On the flip side, most everyone I've heard install them has run into fitment issues. To my knowledge, everyone who's bought them ended up with them installed... Not sent back or given up on. I am undecided between buying a set and making my own.
by Grimor » Sun Jan 25, 2015 11:40 am
this will likely be my next truck purchase unless i get around to making some swaybar links. do all the new kits have the boot and right size bushings so i don't need to cut them down to fit?
Grimor
Rank: Driveway Rated
by SMT59 » Tue Jan 05, 2016 9:02 pm
Good evening all, brand new to the site as a result of being a member at GMTNATION and occasionally lurking, I was looking for information on the Massive kit and was sent over here so I decided to join as I recognize a lot of the members here. So I see a lot of you have installed the Massive kits and sound pleased with them, the question that I have is how much does this change the ride quality, is it harder or relitivly the same? This is my everyday ride for now and I do enjoy the nice ride, I do have a lift on the truck and larger tires, Bilsteins etc., future plans are to go a bit more extreme on the off road and turn it into my toy but for now status quo with some nice mods. :flex dirty:
Don't look back, you're not going that way.
SMT59
by Regulator1175 » Wed Jan 06, 2016 2:42 am
Control arms do not affect your ride quality. Your shocks and springs will.
by v7guy » Wed Jan 06, 2016 12:26 pm
you might maybe get a smidge more clunking over bumps through the rod ended pieces, but given the body is fairly well isolated from the frame I doubt it's noticeable at all. Matt covered the rest.
by SMT59 » Wed Jan 06, 2016 7:38 pm
Good to know guys thanks, I was asking this question as the stock equipment that I want to replace have rubber bushings and the Massive have aluminium and I thought that it may cause clunking that would just p}*% me off every time I heard it if it did. Thanks again.
SMT59
Return to Massive Speed Systems
