by TBYODA » Mon Dec 22, 2014 2:27 am
When not on the trial I have had my spare tire in the back mounted vertically on the left side using the tie downs with two ratchet straps. This was working ok for the most part unless the back seat needed to be down and it would fall over. I needed a better way. So looking around under the back seat I found that one of the seat supports had a hole in it that the hook of the ratchet strap fit in.
Ran the strap under the back cover.
Installed small D bracket on the rear pillar.
Cut out some plastic.
Took three straps to keep it from moving when the back seat is down but it is working good.
by Norcrosski » Tue Dec 23, 2014 6:32 pm
Finally got the front all finished up
Norcrosski
by Wahugg » Tue Dec 23, 2014 8:54 pm
What a busy day! I kicked off the afternoon with just an oil change and then started to tackle the rear axle. After removing both half shafts and inspecting the bearings I decided to replace just the passenger side. After reassembling the rear axle and topping it off with oil I replaced the drivers side seal and oil in my front differential. From here I went over and inspected /re-greased my disconnect just to be sure. Oh, and on top of all of this I did a tire rotation.
It was a pain in the ass but at least I now have peace of mind and a properly running truck.
-Wahugg
Wahugg
by Grimor » Tue Dec 23, 2014 9:38 pm
Put the fogs on top of the truck. They look tiny...
But they put out some very nice light - This is with the driving covers on and no headlights
Grimor
Rank: Driveway Rated
by HARDTRAILZ » Wed Dec 24, 2014 5:13 pm
Wow...
by ErikSS » Wed Dec 24, 2014 9:10 pm
by BowTide » Wed Dec 24, 2014 9:56 pm
Tracked down my PS fluid leak to this pesky little debris/moisture catcher.
http://s1371.photobucket.com/user/Patri ... sort=3&o=4
Luckily it was the return side so I used 5 bucks worth of 3/8" fuel line and a couple of clamps rather than paying 50 for an OEM type. I tie strapped the small leftover piece around the high side line to keep it off the fender well.
http://i1371.photobucket.com/albums/ag3 ... 0b3304.jpg
(spent the difference on these) :drool3:
http://i1371.photobucket.com/albums/ag3 ... 9fe43f.jpg
Screwed around 10 minutes before I could feel my BP spiking trying to get the actual images up, links is best i could do (posted pics before, just forgot how)
BowTide
by BC backroader » Thu Dec 25, 2014 12:59 am
Loaded my family into the "blue bus" and hauled them to my wife's family Christmas Eve dinner get together, where I ate too much and hugged all the pretty ladies.:-)
by maricard » Thu Dec 25, 2014 10:07 am
I had to do the same thing as you Bowtide but at two different places on the same pipe.
I spent the difference on these
Ludwig Mies van der Rohe
maricard
by BC backroader » Thu Dec 25, 2014 1:15 pm
Cheers, Marc, et Joyeux Noel.
by maricard » Thu Dec 25, 2014 1:18 pm
merci à toi et joyeux noel à toi aussi...
maricard
by jhmeg2 » Sat Dec 27, 2014 4:38 pm
So a while ago after I bought the Tundra, towed it home (Cleveland Oh.- mid-Wis), totaled it, had a rear end put in... found that I had a blown rear shock (skyjacker 7000). Replaced both rear with 8000 nitros. Now it sounds like something is super lose in the back. I went back and hit em with the impact gun. Its a little better. It wont tighten any more and still sounds loose. Any ideas? Also I got the Micky Thompson rims back from powder coat. Super happy, except when he blasted them, it took off enough material, that it is no longer stamped MT. I will get a couple photos tonight or tomorrow (they arw out in the shop and not on the truck because I need fender flares.
jhmeg2
by Opeth » Sat Dec 27, 2014 6:56 pm
Took it out of the garage and drove it around the block to circulate fluids, lube surfaces, and got it up to temp then put it back in the garage. Haven't drove it since October, it's nice not having to worry about salt eating it anymore.
by maricard » Fri Jan 02, 2015 6:32 pm
When I bought my TB many years ago I installed a front guard. It was rusty and weak. It was time to do something stronger.
You can see the difference.
I welded bigger pipe instead old one.
This is a work in progress but it look really stronger than original one. I need to replace the middle piece too and fix it on the frame like Karo did.
I'm doing this to install a winch w/o expensive steel bumper. I think it's will be enough strong for me.
maricard
by rScherzer » Fri Jan 02, 2015 10:06 pm
Today I got a set of adaptors in the mail. So I did what any normal person would do and test fitted them with a set of 2014 Silverado wheels and tires. Tires are 265/60r18. I also noticed while I had it on the lift the front shocks started leaking. (Time for some bilstein parts) and a lift!
rScherzer
by 419TrailWisperer » Sun Jan 04, 2015 9:45 pm
Finally got around to installing my ScanGauge II, been waiting on my Blendmount for the gauge.
This thing is awesome, solid construction, installed and wires ran in about 45 mins.
Instructions are on par as well, Pictures and detailed written instructions for every step
although its pretty straight forward, still nice to have.
well worth the $$$ :thumleft:
419TrailWisperer
by Norcrosski » Mon Jan 05, 2015 9:24 pm
Well this happened today just curious how many people have broke a upper control arm
Norcrosski
by ErikSS » Mon Jan 05, 2015 11:32 pm
Dang Andrew! Where did it break?
by v7guy » Tue Jan 06, 2015 1:20 am
Well Andrew, you're not the first, so don't go thinkin you're special lol
I assume you're alright?
by Norcrosski » Tue Jan 06, 2015 1:59 pm
Am I first on pavement at least lol and right behind the pinch for the upper ball joint
Norcrosski
