Skyjacker n8030
by JD8181 » Mon Dec 22, 2014 10:16 pm
I have a 2005 trailblazer that I just installed marks 3" front and 2.5" rear lift. In the front I installed bilstein hd's and in the rear I left stock but am about to order skyjacker n8030's. But when I look at skyjacker's website it says they won't fit. It say they are for 2006 and up. Is that true?? Or will they fit my 2005?
2005 Trailblazer 4x4
4.2
3.42
Mark's 3" lift
PCM of NC
JD8181
by Cable810 » Tue Dec 23, 2014 8:35 am
They will fit you'll just have to shim it with 7/16" grade 8 washers. I used 20 total, 5 on eatch side of the shocks bushing. Check my build.
by djthumper » Tue Dec 23, 2014 12:09 pm
It may say 2006 and up but it will fit. Out of the box they don't fit any of our rigs, we all have to put washers or spacers in there.
by v7guy » Wed Dec 24, 2014 3:11 am
Good advice given.
The fox/bds shocks are the only ones I'm aware of that have adapters specifically for us. I'd encourage you to go that route. This coming from a guy that has each in an envoy and a trailblazer
by JD8181 » Sat Dec 27, 2014 11:16 pm
Thanks for the help guy. I got them installed and used 5 7/16" washers on both sides.
4.2
3.42
Mark's 3" lift
PCM of NC
JD8181
by SmokeyMcBlazer » Thu Jan 01, 2015 12:04 pm
Cable810 wrote:They will fit you'll just have to shim it with 7/16" grade 8 washers. I used 20 total, 5 on eatch side of the shocks bushing. Check my build.
I'm having a hard time finding 7/16 grade 8 washers. Do they have to be grade 8, or are grade 5 ok?
SmokeyMcBlazer
by Cable810 » Thu Jan 01, 2015 12:36 pm
Really?!?! I had no problem finding them. I don't see why they wouldn't work.
by SmokeyMcBlazer » Thu Jan 01, 2015 2:29 pm
I know right....
I'll get the grade 5's
SmokeyMcBlazer
by djthumper » Thu Jan 01, 2015 4:50 pm
They are only being used as spacers so they can just be regular fender washers.
by SmokeyMcBlazer » Fri Jan 02, 2015 3:29 pm
Just gonna post this here for posterity sakes:
When we installed the skyjackers this morning, we didn't use any washers at all. My buddy cut the spacers off the old stock shocks and used the tabs as spacers for the skyjackers. Fit like a glove. A different way to get to the same place.
SmokeyMcBlazer
by maricard » Fri Jan 02, 2015 4:56 pm
Could you send a pic of this please ?
_____LESS IS MORE_____
Ludwig Mies van der Rohe
maricard
by SmokeyMcBlazer » Fri Jan 02, 2015 5:41 pm
i'll try to get a pic from on the truck if I can but I don't know if it'll show well but from this random picture
we cut off the two tabs from the stock shock that come away from the bottom eye (shown at the top of the picture). They are used to fill the gap in the shock bracket on the stock set-up. We cut them off and used them to fill the gap between the Skyjackers and the shock bracket instead of stacking washers.
SmokeyMcBlazer
by maricard » Fri Jan 02, 2015 6:08 pm
thank for this different way...
maricard
