offroadTB.com • View topic - Moots1288 - 2006 GMC Envoy SLT
by Moots1288 » Fri Jun 20, 2014 11:13 pm
Swapped in front differential with 4.56 gear ratio and Lockright Locker
Pulled the diff through the front of the motor after disconnecting Fan and Shroud, AC compressor, Alternator, Ider pulley and Lower radiator hose. There is enough room to just move the ac compressor up ontop of the motor without disconnecting the lines.
by Moots1288 » Fri Aug 15, 2014 5:43 pm
Installed custom Adjustable Panhard bar, had to drill out the axle mount and frame mount for 3/4 Bolts.
Parts-
2- 7/8 thread by 7/8 bore
4- 7/8 by 3/4 misalignment spacers
2- 1" ID by 7/8 thread tube adapters 1 - I got 96" length of 1.5 OD X. 250 wall tube
2- 3/4 X 4 1/2 & 4" grade 8 bolts with nylon lock nuts
Need to get a bolt about 3/4- 1" shorter but this bolt and some washers are fine for now
