by Shdwdrgn » Wed Aug 06, 2014 2:26 pm
Shdwdrgn
Contributing Author
by v7guy » Wed Aug 06, 2014 4:40 pm
James, have you considered some locking header bolts?
by Trail X » Wed Aug 06, 2014 5:04 pm
No, but please enlighten me.
by v7guy » Wed Aug 06, 2014 5:19 pm
There's a few versions, one with a wing, one with "cammed" (for lack of a better term) washers and one with a set screw in the bolt head
http://www.jegs.com/p/Stage-8/Stage-8-L ... 5/10002/-1
http://www.proformparts.com/product-exe ... ory_id/320
http://www.jegs.com/p/Percys/Percys-Vib ... 9/10002/-1
by Opeth » Fri Aug 08, 2014 8:38 pm
Somebody is running around naked....
....and it's not meeeeeee!!
by TBYODA » Fri Aug 08, 2014 8:53 pm
by Opeth » Fri Aug 08, 2014 9:07 pm
Some good guy in Rochester :)
by Shdwdrgn » Sat Aug 09, 2014 12:10 pm
I actually got a small functionality test of my bumper on Thursday. Had to tow the wife's Blazer back to the house so I could work on it, but first we had to get her out of the parking lot. I got a HF snatch-strap awhile back, so I looped it around her rear hitch and pulled her out of the parking spot. Yeah it wasn't a big deal, but it was sure nice having an option other than trying to push her uphill by hand. Then I towed her home and got her parked in front of the house. In other news, I think I got too heavy a snatch-strap. While towing, it didn't seem to have any snap at all, which would have been nice since she's never helped tow a vehicle before. I think this strap was rated at 15,000. Oh well, still a really nice strap to have for moving vehicles.
Oh, and it turned out to be both the battery and starter failing. I managed to get a couple more hesitant turns out of the starter before the battery went dead. By the time I took the starter out of her truck yesterday, it was completely gone (parts store tried testing it, couldn't get it to do anything). So I'm out $200 for repairs, but she shouldn't have any more problems for awhile.
Shdwdrgn
Contributing Author
by ErikSS » Sat Aug 09, 2014 12:42 pm
Not all nylon straps are intended to stretch. There is a good amount of information on that topic.
by Shdwdrgn » Sat Aug 09, 2014 3:04 pm
It was sold as a stretchable recovery strap. Just looked it up, it appears to be an 18,000 pound strap, plus I was using it doubled-over between vehicles. I got it because it was on sale cheap (actually on sale again for $16), and it's easy to carry in the storage area along with jumper cables, hitch, and tow loop. I seem to remember that a recovery strap rating was supposed to be about 2x the vehicle weight? I dunno, if I used it as a single line, it would probably have some snap to it, but doubled-over it was just the right length for towing through my neighborhood.
Shdwdrgn
Contributing Author
by Chango » Sun Aug 10, 2014 4:18 pm
Went to Bundy Hill and gave her a workout. Surprised me and everyone I was with what it could do in 2wd! Image
And saw a north face tb too. Image
Chango
by Shdwdrgn » Sun Aug 10, 2014 5:17 pm
I don't know why I didn't think of this before, but I found the perfect place to mount my inverter today... Under the rear passenger seat where the OnStar unit used to be. I made up a plexiglass plate to fit in the slots, then siliconed the inverter down (there are no mounting slots on the case). There's actually quite a bit of space under the seat, leaving it open for airflow around the fans, and it sits perfectly where you can plug something in by opening the door.
Yes, it's only a tiny 750W (1500 peak) unit. Its more of a just-in-case thing, although it appears I have plenty of room to upgrade to a larger model later if needed. I'm just going to tie the ground to one of the seat bolts, and then run a wire over to the 125A line in the fuse block. It appears the unit has an internal 35A fuse, but I might add another external fuse. Any suggestions on what gauge wire to hook this up with? It came with 00 wires (9mm) which are too short to reach, but that seems a bit overkill if it draws less than 35A?
[Edit] Hmm a quick calculation shows that 1500W at 12V is 125A... So how are they using a 35A fuse in this thing? Yeah I definitely need to do some more reading before choosing my wire size.
Shdwdrgn
Contributing Author
by Trail X » Mon Aug 11, 2014 8:52 am
My guess is that the 35 amp fuse is an internal circuit protection, and does not fuse the A/C output supply.
by ErikSS » Mon Aug 11, 2014 8:57 am
I'm not an electrician, but I think your math is off. I'd bet its closer to 12.5 than 125. Do we have an electrical engineer that can confirm or deny his amp rating based on Watts and volts?
Edit: I believe its 1500 amps at 110 volt, that's the output not the power draw.
by Shdwdrgn » Mon Aug 11, 2014 9:13 am
Yeah you're right, I was figuring from the wrong side of the power rail. 1500W at 120V is 12.5A. And no real idea how that converts to the 12V side. I could guess at 90% efficiency, and calculate about 13.9A draw, but I could also guess that peanut butter makes it run cooler... its just meaningless. The stupid manual that comes with it has no useful information -- no recommendations for wire size or current draw. They just assume everyone is going to use the included clips and connect directly to the battery at all times, and there couldn't possibly be any other way this thing would be used. Ugh. Maybe some digging online will turn up some info that others have found.
Shdwdrgn
Contributing Author
by ErikSS » Mon Aug 11, 2014 9:37 am
Most manufacturers spend as little as possible. So the guage they used would probably be as thin as I would suggest.
by Trail X » Mon Aug 11, 2014 10:20 am
Power is what stays the same across the voltage conversion. You had it right to begin with.
by ErikSS » Mon Aug 11, 2014 10:41 am
James, have you tried to use a 30 amp appliance on a 1500 amp peak inverter? It doesn't come close. I can hardly use 5 amp appliances with my 750 constant/1500 peak inverter. Amps are a ratio of wattage at a certain volt. It is directly affected by both. It sounds like he has the right formula but had mixed up input and output for numbers to plug in.
by Shdwdrgn » Mon Aug 11, 2014 10:54 am
So it seems folks on other offroad forums are suggesting 6ga or 4ga wire to hook this thing up. What I don't understand is that this seems a lot larger than the wire used for the 125A feed to the rear fuse box. Did I mis-read the rating on that wire, or am I just totally off in left field here?
James, you would think I would know these things -- my dad was an electrician and I have an EE degree. You're right, power stays the same, so the 750W is the same on both sides of the rail, meaning that a lower voltage requires an increase in amperage. So 125A at peak usage is reasonable. Now the only question is if I actually HAVE that much power available under the seat, or if I need to run a dedicated line up to the battery.
Shdwdrgn
Contributing Author
by Trail X » Mon Aug 11, 2014 11:54 am
