Bad wheel bearing after <10,000mi?
by Pitch22 » Sun Aug 03, 2014 6:44 pm
Hey guys. Iv searched for about this topic a lot but I havnt quite found what I'm looking for. This past winter I replaced both my front hub assemblies. For about the past week iv been having a slight vibration in my steering wheel. There's also a slight hum around 40 mph. This seems different than the wheel bearing problems I had because the sound doesn't change if I turn left or right and the noise is much quieter then my bad bearings were. It's mainly the vibration in the steering wheel that's annoying. What could this be? Cv axle? Low diff fluid? Any help is appreciated. Thanks a lot.
Pitch22
by ErikSS » Sun Aug 03, 2014 7:18 pm
I would start with rotating your tires. It sounds like a tire out of balance to me. It's never a bad idea to check your diff fluid though. FWIW, I've heard of bearings going out that fast, and faster.
by Trail X » Sun Aug 03, 2014 8:18 pm
Especially the Ebay bearings.
But a vibration in the steering wheel would generally point to a front wheel imbalance, or if its during braking only, bad rotors.
Not sure what the hum is from. That particular part of your story does jive with a bad wheel bearing.
by Pitch22 » Sun Aug 03, 2014 8:21 pm
I forgot to mention. I had brand new tires put on about a month before the vibration started. Then a 2.5" lift put on right after the tires. Everything was perfect for about a month and then the vibration and noise started. Could the lift have thrown it out of balance and it's just not showing until now?
Pitch22
by ErikSS » Sun Aug 03, 2014 8:29 pm
Did you have it aligned after the lift? You're tires could be wearing uneven if you didn't, or if you didn't let the springs settle in before you had it aligned.
A wheel weight could have come off.
by Pitch22 » Sun Aug 03, 2014 8:45 pm
No I didn't have it aligned. Probably should have. I'll get the tires taken care of this week. Hopefully that will fix it. I dont know why I didn't think of that first. Thanks guys
Pitch22
by harvyne » Sun Aug 03, 2014 9:08 pm
hope you didnt ruin your tires man, good luck
harvyne
by Pitch22 » Mon Aug 04, 2014 5:20 pm
So I got just got under my truck and I noticed there's grease around my cv axle. The hose clamp on the smaller end of the rubber boot somehow got losse (I can slide it with just my fingers). Could a dry cv b the cause of the vibration?
Pitch22
by v7guy » Mon Aug 04, 2014 9:16 pm
All your problems are likely centered around you never having it aligned, hope you didn't wreck the tires already. Go get it aligned.
For the CV boot, pull the CV, clean it up, repack with grease and reclamp the boot.
by Pitch22 » Mon Aug 04, 2014 11:53 pm
Surely it hasn't ruined the tires. There's only about 3,000 on them. I'm getting it aligned this week. One more quick question for you guys. Iv been thinking about getting z71 springs in the back and moog 8114 up front. I already have mark's 2.5" lift. Would those springs be safe to add or is it too much lift for the suspension? I believe it would be roughly another 1.5" in the front and back.
Pitch22
by Moots1288 » Tue Aug 05, 2014 8:27 am
A few hundred miles on an unaligned suspension will wrecks tires... Experience.
by Eredin » Tue Aug 05, 2014 9:16 am
I had to drive mine for two weeks while waiting on a control arm to come in, plus alignment to be scheduled. While I only did around 150 miles total, keeping it minimal as possible, you could see the front tires starting to scrub really bad due to the toe in. I rotated them to the back after alignment, and no damage was done, but after 3000 miles you'll have severe wear. It doesn't take much to annihilate them.
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
