offroadTB.com • View topic - Possible Speedometer and Abs fix for gear change
by bspellman » Wed Jun 25, 2014 12:14 pm
I was browsing though summit racing's website and spotted this
Curious if anybody has tried this or if I discovered a possible fix.
bspellman
by Eredin » Wed Jun 25, 2014 2:39 pm
Interesting. I just have my Scanguage II adjusted 7% for mine since my stepper gauge on the speedo is broke anyway. You get more information displayed to your preference for about the same money.
Just throwing it out there as an option.
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
by Gordinho80 » Wed Jun 25, 2014 6:34 pm
Scanguage doesn't correct what the vehicle's computer is seeing, as this claims to do. It is definitely interesting
Mario -
by Eredin » Wed Jun 25, 2014 10:28 pm
Eredin
by Trail X » Wed Jun 25, 2014 11:11 pm
Depends on what gears you are switching from/to. It doesn't seem to have enough turns to handle the change from 3.42 to 4.56, but it can handle 3.42 to 4.11.
A possibly better option was posted by Dirty Anton a couple years ago. I have been lookint into it as an option for me.
by ErikSS » Thu Jun 26, 2014 8:27 am
Which years can't be adjusted with the PCM? Barton told me once but I'm not 100% sure. PCM of NC adjusted my (2008) speedometer without additional charge when they did my Tune.
by Cable810 » Thu Jun 26, 2014 9:14 am
Wasn't it 06 and up we can correct and any years under we can't. BTW I had to set my scanguage at -13%
by v7guy » Thu Jun 26, 2014 10:45 am
if you're primarily concerned with the speedo then Anton's method works fine.
But if we're having issues with ABS cause the computer doesn't see the right signal, then I would think Antons method wouldn't work as he mentioned when it was hooked up pre PCM he kept getting error codes.
by Trail X » Thu Jun 26, 2014 2:06 pm
I hadn't remembered reading that, but I trust you. Thats disappointing. I didn't see any warnings against it on their website. I have seen a few things that seem like they would do it, but I guess the ABS system is a bit touchier than the speedometer gauge. I need to read into it more I guess.
I beleive the programming cutoff for speedometer settings is the implementation of the CAN protocols. I think that was 2006+. I don't know if 2006+ can adjust gear ratios.
by Shdwdrgn » Tue Jul 08, 2014 5:12 pm
2006+ is the cutoff. 2002-2005 used the P10 PCM, which has no aftermarket support for changing the gears (but we do have files available to update to different factory gears). The newer models use the P12 PCM, which does have support in aftermarket programmers to adjust both the gears and tire size.
@Gordinho80 -- I thought you was going to use the HPT file I sent to you to reprogram yours. Whatever happened with that? It seems like programming the PCM with the correct information would be far better than using an aftermarket solution that only mucks with the signals.
Shdwdrgn
Contributing Author
by TBYODA » Tue Jul 08, 2014 7:55 pm
by Shdwdrgn » Tue Jul 08, 2014 9:35 pm
Shdwdrgn
Contributing Author
by DirtyBacon04 » Thu Jul 10, 2014 10:34 am
Well back to the origin of this thread...
Assuming no one has experience with the item linked in the OP? Is there any reason it wouldn't work for us?
Would it only correct our speedo and not ABS due to the location of our sensors? I have next to nothing knowledge wise about PCM programming.
According to the application guide it'll work for a 2004 LS
by Trail X » Thu Jul 10, 2014 12:34 pm
As I said before, it should be ok for 4.11 gears, but it doesn't seem to have enough adjustment range to adjust for 4.56 gears.
The question is which VSS controls the abs. If someone had a working system, they could try unplugging one of the two and then letting us know which lights come on. Not sure if the speedo uses the VSS as the abs either.
by TBYODA » Thu Jul 10, 2014 1:42 pm
by Trail X » Thu Jul 10, 2014 2:35 pm
You'd have to talk to the manufacturer to answer that one.
by TBYODA » Thu Jul 10, 2014 2:54 pm
by larryk » Thu Jun 09, 2016 9:33 am
Hi guys.... Well, I made the switch (FINALLY) from Trailvoy over to here. Im getting my weinerdog turned into more of a real truck..... I know, not ideal for offroad, but I do want it more capable than what it was.
Soo.....has this issue on a 2004 ever been resolved? I just swapped out the rear axle for a 4.10 (from 3.42) and have the front driveshaft off while Im building up my courage to tackle that front one! I had the PCM reprogrammed, as the original programming was, obviously, way off and it threw the ABS/Brake lights. Got the PCM back, and the trans shifts better, but a)my speedo is still off, and b) after a few miles...damn ABS/Brake light threw down again.
I realize with the 3 channel ABS that the rear input to the ABS comes from the PCM, which is then compared to the front ABS sensor wheel speed. Since the wheel speed is independent of gear/tire size, Im 99% sure the issue is coming from the PCM translating transfer case output shaft speed to wheel speed.....and boom, christmas tree lights on the dash :(
Any help/advice on this is much appreciated
THANKS!!!
larryk
by tarsh » Thu Jun 09, 2016 9:53 am
I have the swb 4.2 and i as well swapped for a 8.6 rear end with 4.10. In my experience the abs light came from a front hubs Because the wire got pulled on the driver side. My pcm was tuned and i have the 04. So I'm willing to bet it's the hubs abs wire.
Take the path less traveled
tarsh
by larryk » Thu Jun 09, 2016 11:06 am
larryk
Return to Off Road Discussion
