z71 rear springs
by MartinTheLaker » Fri Apr 25, 2014 11:33 am
Hello,
So after reading that 89 springs are the stiffest and offer the most (but still small) lift for our front stock springs. I was just wondering if it matters which z71 rear spring to buy?
MartinTheLaker
by The Roadie » Fri Apr 25, 2014 11:52 am
There is only one stiffness of the 2007+ Tahoe/Avalanche rear springs. No choices on that platform because a rational design team worked on it. Not the children with inadequate adult supervision that did our platform and the very similar HHR.
by ARC- » Wed Jun 25, 2014 1:41 pm
I just installed the Z71rear springs on my 97x 5.3 and it drives great. Installation was easy. Yes, i removed the fuse.
97x 5.3 LH6 ŘWD
SPRING LIFT ONLY ON 33"
Z71 springs!
ARC-
DriveTrain: AWD
by Ole Blue » Thu Jul 31, 2014 3:20 pm
ARC- wrote:I just installed the Z71rear springs on my 97x 5.3 and it drives great. Installation was easy. Yes, i removed the fuse.
What's the part number for those z71 rear springs and did you use the 2" blocks too?
Ole Blue
by ARC- » Thu Jul 31, 2014 8:55 pm
I dont have the part #. I did not use the 2" spacers. I just have the new Upper control arm bushings and front 3" spacer. I am waiting on the front shock and springs, then I'll install it all and decide then if I will install the rear 2" spacer or not.
97x 5.3 LH6 ŘWD
Z71 springs!
ARC-
DriveTrain: AWD
by TBYODA » Fri Aug 01, 2014 12:17 am
I'd suggest that you read this thread. Z71 Springs
