by Trail X » Thu Apr 17, 2014 8:17 pm
3
by HARDTRAILZ » Thu Apr 17, 2014 11:28 pm
by v7guy » Fri Apr 18, 2014 12:55 am
by Moots1288 » Fri Apr 18, 2014 12:57 am
by DirtyBacon04 » Fri Apr 18, 2014 2:35 am
Bought some new cookware and came up with a genius storage spot for my over-the-fire grilltop.
I've had this for years. I was keeping it in the cab, but it would get too covered in tasty grill-goo... But it was always dirtying up anything else around it. I know this location will get it covered in dirt/mud/etc. but hell, it's going to get put over a fire and scrubbed with a grill brush prior to use, so no biggy. I had to cut out a small section to get the bracket to fit through, but no modifiations to truck necessary.
by CarbEnvoy » Fri Apr 18, 2014 4:14 am
Got rid of the air ride suspension, installed Raybestos XL/EXT springs and insulators, and replaced the front swaybar bushings. Gained about 1 1/2" over the air springs at the center of the wheel well, and I now have about 3" of rake. It level out the front too. Used to be almost an inch lower on the passenger side. Now they are the same. Must've been a leaky air bag, they were in bad shape.
On the down side. I checked the axle disconnect, and found quite a bit of play at the inner CV. Guess a rebuild may be in order. :(
CarbEnvoy
by HARDTRAILZ » Fri Apr 18, 2014 6:33 am
by bgwolfpack » Fri Apr 18, 2014 11:24 am
:idea: Michael :cheers:
Hence, your screen name.
by djthumper » Fri Apr 18, 2014 12:36 pm
by TBYODA » Fri Apr 18, 2014 1:28 pm
by Trail X » Fri Apr 18, 2014 10:42 pm
Bacon, I like it, but I don't like the spare tire winch. That thing gets jammed sometimes, especially if there isn't enough weight pulling on it. But I DO really like the idea of using that space. I've been wanting to put either a secondary gas or water tank under there... in due time I guess.
by The Roadie » Fri Apr 18, 2014 11:30 pm
You know that's the exact cookware set I have. Roadie Fan Boy should be your screen name. I'll take a pic for proof.
by DirtyBacon04 » Sat Apr 19, 2014 6:11 am
Jam... I mean, Trail X: Yea, the winch gets to be a pain in the ass if there's no weight on it. Luckily for this application, it only has to be lowered a few inches to get the grill on/off.
Roadie: If I'm purchasing the same things as you, without knowing you've already bought them, that gives me a special level of confidence :) After all Bill, you are my inspiration/mentor that got me headed down the right trail(s)
by Cable810 » Sat Apr 19, 2014 10:09 am
I stared at it....... Wishing it was fixed :lol:
by ErikSS » Sat Apr 19, 2014 10:24 am
I raised my radiator.
I decided to go electric fans which meant my fan and shroud are no longer tied to the height of the engine. so I cut off my radiator mounts. I shortened them 3" and welded them back on. I did not have to change any hoses or anything.
I'm really happy with the results. I hope to have better air flow, less damage risk, and I now use the OEM upper radiator mount with my body lifted truck.
by Trail X » Sat Apr 19, 2014 11:48 am
Smart change. Makes complete sense with a body lift. Any issues with the engine coolant hoses or transmission lines?
And Bacon, you can still call me James or JD, its still my name.
by ErikSS » Sat Apr 19, 2014 12:27 pm
by dvanbramer88 » Sat Apr 19, 2014 1:13 pm
by DustinC1989 » Sat Apr 19, 2014 1:14 pm
I like option 2 personally since I plan on doing the same thing down the road
DustinC1989
by dvanbramer88 » Sat Apr 19, 2014 1:23 pm
Fixed my exhaust leaks. Deleted my suspect to be bad cats. Truck feels and sounds better. PCMforless tune in a few weeks.
