by Cable810 » Sat Apr 12, 2014 7:01 pm
Went to wheel today to only find out that my 4wheel dive isn't working :wallbash: Thankfully I realized that it wasn't working after 100 yards off pavement.
by Cable810 » Sat Apr 12, 2014 9:07 pm
Yay me :wallbash:
by The Roadie » Sat Apr 12, 2014 9:32 pm
That took a few miles to get that bad.
by Cable810 » Sat Apr 12, 2014 9:50 pm
Yeah, best of all I have NO CLUE how that happened. It was working fine the last time I used it which I think was October. So is it a bad disco? Assuming that it is.
by Trail X » Sat Apr 12, 2014 10:11 pm
Uh, that's just normal wear, dog. Time to tear into it. At min you will need 2 new bearings and a seal. More likely it will be more than that.
by Cable810 » Sat Apr 12, 2014 10:14 pm
I swear stuff like this happens right after I spend some money on other things :wallbash: Should I just get a new Disco Or rebuild it?
by Moots1288 » Sat Apr 12, 2014 10:17 pm
by ErikSS » Sun Apr 13, 2014 10:31 am
I had to cut a hole threw both layers of my strut tower to allow access to the damaged spark plug thread. Once I had straight on access I was able to tap the threads clean and install the spark plug. Using hole saws, I had made a larger hole in the front piece. The cut out from the front piece was close to the right size to fill the back plate. I made a new plate for the front strut plate. I decided it was enough excitement for one day. Hopefully I don't have anymore of these issues.
by Chango » Sun Apr 13, 2014 11:39 am
Chango
by Cable810 » Sun Apr 13, 2014 1:15 pm
by RyansTBLS » Sun Apr 13, 2014 3:03 pm
Replaced Idler pulley, I think it was original :facepalm: and got rid of that noise
and made it easier to pinpoint the noise I've been chasing, looks like the power steering pump pulley :wallbash:
now I need to figure out if I have to replace the whole thing :wallbash:
RyansTBLS
by Chango » Sun Apr 13, 2014 3:20 pm
Chango
by DustinC1989 » Sun Apr 13, 2014 3:41 pm
DustinC1989
by DustinC1989 » Sun Apr 13, 2014 10:10 pm
Switched all the grease zerks to 90* zerks so they are easier to get to
DustinC1989
by HARDTRAILZ » Mon Apr 14, 2014 12:00 am
New diff fluid n some rust control
by Cable810 » Mon Apr 14, 2014 12:17 pm
For Future reference are the CARDONE 66-1345 CV Half-Shaft a 36MM Nut?
by dvanbramer88 » Mon Apr 14, 2014 12:22 pm
by HARDTRAILZ » Mon Apr 14, 2014 12:26 pm
36mm socket works on stock and aftermarket CVs.
by Wahugg » Mon Apr 14, 2014 1:06 pm
Same goes for the 35mm. That way you can re-use the oem nut and save yourself the need to buy a 36mm socket.
-Wahugg
Wahugg
by HARDTRAILZ » Mon Apr 14, 2014 1:50 pm
