by HARDTRAILZ » Tue Apr 08, 2014 11:31 am
navigator wrote: how well you plan to tie stuff down.
What is the world does that have to do with side height? You better tie anything up there securely or you are a f'ing dumbass.
by bgwolfpack » Tue Apr 08, 2014 11:40 am
Grow up Kyle. You know what Chris meant (I hope). :slap:
by HARDTRAILZ » Tue Apr 08, 2014 11:45 am
Kindly go F yourself.
I don't know why he would put something so ignorant.
by ErikSS » Tue Apr 08, 2014 11:49 am
"Grow up Kyle" hahaha At least I'm not the only one with that sentiment.
by HARDTRAILZ » Tue Apr 08, 2014 11:54 am
ErikSS wrote:"Grow up Kyle" hahaha At least I'm not the only one with that sentiment.
Hahaha. You n your girl can f off as well. No use for you at all.
by ErikSS » Tue Apr 08, 2014 12:01 pm
I'm aware. I'm glad to see you continue to show your colors on the forum. Throwing around words like ignorant. Getting all excited over stupid shit. Overall insulting people without reason. I can manage without those things in my life.
by HARDTRAILZ » Tue Apr 08, 2014 12:09 pm
:D
by Trail X » Tue Apr 08, 2014 12:30 pm
There is some truth to what Chris said. If I've got some walls, I really only need to run one strap, and that's often just a bungie. If there are no rails, every load needs at least two straps.
by HARDTRAILZ » Tue Apr 08, 2014 12:38 pm
JamesDowning wrote:There is some truth to what Chris said. If I've got some walls, I really only need to run one strap, and that's often just a bungie. If there are no rails, every load needs at least two straps.
I can understand that, but it is not how well you tied it down. Either way is well tied. You are just using the side as a control point rather than a secondary strap.
by TBYODA » Tue Apr 08, 2014 12:47 pm
Went and got my TB alignment after my lift. My cuz shop did a pretty good job.
by HARDTRAILZ » Tue Apr 08, 2014 12:57 pm
Looks like they did a real good job.
by Cable810 » Tue Apr 08, 2014 1:02 pm
Tried to tune my Cb antenna and It wouldn't tune no matter what I tried :wallbash:
by navigator » Tue Apr 08, 2014 1:12 pm
that's exactly what I meant.
I use "milk" crates to carry stuff on the rack I built. Since my walls are tall enough I can put the crates at the rear of my rack and run a strap through the crates and one strap can hold 2-3 crates in place.
If my walls weren't tall enough or if I had no walls, I would need to be more diligent in securing the load.
by TBYODA » Tue Apr 08, 2014 1:18 pm
HARDTRAILZ wrote:Looks like they did a real good job.
Yea they are a custom shop and lift suv's and trucks all the time. Had to also have replace a outer TRE cause it would not pass inspection. I bought the part but did not think they charge me $80 to install. Should have done myself, lesson learned. :wallbash:
by TBYODA » Tue Apr 08, 2014 1:21 pm
Cable810 wrote:Tried to tune my Cb antenna and It wouldn't tune no matter what I tried :wallbash:
Make sure you are away for other cars during adjustment, just added to the difficulties. What you seeing for swr?
by HARDTRAILZ » Tue Apr 08, 2014 1:23 pm
I could easily secure 2 or 3 milk crates with one strap on my flat rack. They would be secured well actually. Sides are not needed. Are you letting the crates slide into the walls or how do you think the walls secure that load? If they are along the rear of the rack, what keeps them from sliding forward when braking?
Sounds like you don't need to be more dilligent and you are securing your load well, but sides are not why.
by KingBird » Tue Apr 08, 2014 1:30 pm
KingBird
by Gordinho80 » Tue Apr 08, 2014 1:35 pm
You might want to take your basket build post into its own thread... just saying.
by HARDTRAILZ » Tue Apr 08, 2014 1:37 pm
KingBird wrote:OK guys, I'm still new to some of this, I'll be adding some expanded metal to the bottom and sides, which I'm thinking need only be as tall as my lights. Do those bungee "spider straps" work as advertised or are they more trouble than they're worth?
I find them more trouble than worth. Regular bungees and ratchets are far easier. Occasionally with a wierd or multiple piece load i will utilize a spider over top of everything I have alredy secured, but its more for added peace of mind than actually holding anything.
by Trail X » Tue Apr 08, 2014 1:38 pm
More trouble than worth, X2. They are really only good for tying down light loose stuff.
