Wheel Spacers/Adapters/Backspacing Information
by Zero » Fri Oct 22, 2010 12:03 pm
Its all good brother! :friday:
by HARDTRAILZ » Mon Oct 25, 2010 1:37 am
Wheel centric is a waste if you ever plan to have more than one set of wheels or change wheels in the life of your truck. Also you have to have a matching spare and possibly could not borrow a spare if you happened to get 2 flats on a trip. I have 4 full sets of wheels and tires and have had several other sets all on my perfectly capable ebay spacers. Not one issue and mine are 1.3 inches. I take my time and DO NOT USE air or power tools on wheels, never have, so i get no vibrations with my spacers.
If you got money to waste, give it to fred. If you want a good product for a fair price, buy from Mark or ebay. They both accomplish the exact same thing, but fred's product could limit you in the future or a time of need.
by harvyne » Mon Mar 31, 2014 11:25 pm
ok trying like hell to find a 1.5 wheel spacer with a 6x127 to a 6x127 to keep my stock envoy rims, can anyone give me the link to this Mark person or any other company that has them. im having no luck on ebay
harvyne
by Moots1288 » Mon Mar 31, 2014 11:27 pm
go to the vendor section
by HARDTRAILZ » Tue Apr 01, 2014 5:41 am
Someone just posted a set for sale on here as well
by Trail X » Tue Apr 01, 2014 8:22 am
You'll probably find it called 6x5 more often than 6x127
by Dante2113 » Mon Feb 01, 2016 5:07 pm
I've had some bad experiences with wheel spacers in the past, and I'm looking to get my back spacing from a new wheel setup. However, I'm a little confused by what James meant by "obtaining a wheel with less than ~5".
A stock 16" wheel with a 1.5" spacer should have 4.5" of backspacing, correct? If so, why would a wheel with 5" of backspacing do just as well?
I've got an aftermarket wheel I'm looking into that comes in two sizes: 17x8 with +10mm offset OR 17x9 with -12mm offset. The 17x8 (+10mmET) will give me 4.9" of backspace, but if it's not as much backspace as the stock 16" wheel + 1.5" spacer, I plan to buy the 17x9 (-12mmET) wheels which will equate to 4.5" of backspace.
Dante2113
by HARDTRAILZ » Mon Feb 01, 2016 6:41 pm
People do 1.5 inches to avoid cutting factory studs. You could do one inch and trim the studs
by Tricguy007 » Sun Apr 15, 2018 5:25 pm
I just bought a set from the Lug Nut Guys on eBay and they even have 12.9 studs only hub centric
Tricguy007
Name: grant Huskelhus
by Tricguy007 » Mon Apr 16, 2018 12:36 am
If you use Saab 97x wheels you don't need to cut the wheel studs, spacers I'm running 1.25" spacers, the wheels have a pocket between the stud holes so the .25" the studs stick out doesn't interfer with the wheel
Tricguy007
by Thatguy » Wed Nov 04, 2020 6:21 pm
So if I have 18x8 rims with a 5 3/4 back spacing how wide of a spacer do I need to put a 33" tire on my 04
Thatguy
DriveTrain: AWD
by Giovanni20 » Tue Sep 14, 2021 5:16 am
Those asking if it's safe.They really are.A vehicle's wheels are actually held to their corresponding hubs with a clamping force that is achieved through the tightening of each wheel's lug nuts
Giovanni20
