by The Roadie » Wed Mar 26, 2014 7:00 pm
DirtyBacon04 wrote:This, ladies and gentlemen, is what a breakdown in prioritization looks like...
Agreed. I don't want to hear that the recovery equipment fund has been depleted to get the armor. The body lift is about the LAST major functional mod I did, and I resisted it for years. (Counting the rear bumper as mostly decorative)
by galacticfuzz » Wed Mar 26, 2014 7:26 pm
Finally got the cancer removed from under the sides. Should have been done three years ago when I removed the cancer that was my exe.
Also straightened up the interior after a weekend of traveling (Sunday-Tuesday) with the kids and girlfriend.
― Antonio Porchia
galacticfuzz
by Moots1288 » Wed Mar 26, 2014 8:10 pm
:thumleft: Changed driverside wheel hub, found every bushing on the mevotech arms are completely shot...
by Trail X » Wed Mar 26, 2014 9:27 pm
HARDTRAILZ wrote:Seems to have been tried alot, but still not seeing enough failures to justify spending much on an alternative when the stockers have proved adequate for most over the years. I like to to know where the fusable link is and know its easy to replace on a trail.
However....I am curious to what you have found???? How are UCA working out?
I'm not trying to overdo it, and the cost isn't bad. I was really just curious if I could find something incrementally better, plus my current TREs are pretty much shot at this point. This solution uses a CrMo threaded link. So hopefully I won't need any special sleeves to reinforce it like some of the other upgrades we've seen.
Its kinda a pieced-together solution. Parts came in today, so I'll try to get it on the truck when I have time (too many spring house projects right now). Will post up a thread when I have something concrete. As is, it may not even fit, and I could just be out $120. [/Teaser!]
UCAs are still kicking. Saw one of my uca bolts loosened a touch, need to get in there and tighten that bad boy back up a bit more than before.
by Eric_Kruger » Wed Mar 26, 2014 11:53 pm
Did some minor cosmetic stuff, got rid of the rear hatch handle, plasti dipped the grille, and measured out the starting pieces of a drawer for the back to hold all my camping/ fishing gear.
Eric_Kruger
by Trail X » Thu Mar 27, 2014 9:06 am
Flat tire... :hissyfit:
Still need to go plug the hole and refill the flat tire.
by HARDTRAILZ » Thu Mar 27, 2014 9:16 am
That sucks.
by Trail X » Thu Mar 27, 2014 12:22 pm
The bad thing is that this is the second flat that I haven't immediately recognized. Drove about 15 miles on it at 70mph.
by boog2006 » Thu Mar 27, 2014 1:33 pm
JamesDowning wrote:The bad thing is that this is the second flat that I haven't immediately recognized. Drove about 15 miles on it at 70mph.
Really? I always kinda chuckle at those people running down the interstate...oops :drive:
Boog2006 Build Thread
boog2006
by DirtyBacon04 » Thu Mar 27, 2014 2:42 pm
you must've picked up one of the fancy deflators we were discussing earlier. please post your results (nail size, material, psi deflated to, etc..)
by Trail X » Thu Mar 27, 2014 6:53 pm
That's the sad part, so do I. It didn't even feel squirly. I need to add the caveot that I recognized it after being parked for about 1 or 2 hours, so it might have mostly deflated while parked. No idea if I actually drove with it fully deflated, but there were wear marks on the sidewall, which makes me think it was fairly well deflated.
Bacon, attached is the thin piece of steel in my tire. No idea what it is. Metal is quite brittle, kind of like a razor blade. 0 psi when I changed it out. Rim was sitting on the ground.
Edit - actually, now that I played with the parts a bit more, that's exactly what it is, a box cutter blade. Hm.
by Regulator1175 » Thu Mar 27, 2014 11:14 pm
I would say someone doesn't like you.
I had a box cutter blade in one of my Bravada tires a month or so ago. I am certain that it was propped up against the tire so that when I backed out of the parking spot I forced it into the tire.
by galacticfuzz » Thu Mar 27, 2014 11:27 pm
James, time to get a trail cam set up and hidden. Sucks that it would seem to be intentional
― Antonio Porchia
galacticfuzz
by Trail X » Fri Mar 28, 2014 9:49 am
It really looks like it's been in there (or on the road) for a long time. It wasn't like it was pristine by any means. And if someone really wanted to pop my tire, I'd go between the lugs, not into the middle of a lug. I'm not suspecting foul play the more I think of it.
by navigator » Fri Mar 28, 2014 9:53 am
when I used to work in a tire shop, I pulled a dog tooth out of a flat one time.
The lady was like "yeah, we ran over a dog the other day but didn't think much of it at the time."
by HARDTRAILZ » Fri Mar 28, 2014 9:57 am
Regulator1175 wrote:I would say someone doesn't like you.
Need me to come help give em an attitude adjustment?
by mikekey » Fri Mar 28, 2014 12:58 pm
I keep a set in the car just for asshats who park right up against my door. :lurk:
by navigator » Fri Mar 28, 2014 1:07 pm
we only do that when you take up two spaces! j/k
by Cable810 » Fri Mar 28, 2014 2:37 pm
Ordered some stuff for the Trailblazer. Receiving on of those items today!! April 5th and 12th cannot come fast enough
Edit: Speakers Just came in
by NC_IslandRunner » Fri Mar 28, 2014 6:24 pm
Ordered power steering pump, should be in before I get the TB back.
