*SOLVED* no 4x4, no lights, no nothing!
by DustinC1989 » Tue Mar 18, 2014 7:55 pm
As far as I know, no kit. But the parts are available pretty readily
DustinC1989
by tarsh » Tue Mar 18, 2014 8:10 pm
Mk. Well u asked where the TCCM came from. 02 trailblazer from the salvage yard. Came in that morning. Fixed the service 4wheel light. All noises are there and it's saying I'm in 4, so I'm assuming it's ok. The guy looked up the part number off it and it said works for 02-05 trailblazers... That TB has all the things I need as far as cv shafts, disconnect, actuater, transfercase, and a G80(wich i might scoop up as well)
Take the path less traveled
tarsh
Name: Nathan Schroeder
by The Roadie » Tue Mar 18, 2014 8:23 pm
tarsh wrote:...TCCM came from. 02 trailblazer from the salvage yard. ...
You must have missed the memo that 2002 TCCMs are to be shunned. Might work now, but I wouldn't trust it long term. :facepalm:
by tarsh » Tue Mar 18, 2014 8:26 pm
Damn.... Can't catch a break can I.
tarsh
by djthumper » Tue Mar 18, 2014 8:54 pm
If you haven't purchased it yet, you caught a break...
by tarsh » Tue Mar 18, 2014 9:00 pm
True. I manually pushed the splined disconnect into place and it still didn't lock 4 wheel
tarsh
by Wahugg » Tue Mar 18, 2014 9:29 pm
Define what you mean by no 4x4?
Right now I can't really tell you much. From my understanding your TCCM is currently not working. It was off a 2002 and then is just died..
Manually engaging the disconnect means nothing. Lets say you used a screwdriver to engage it, what will keep it engaged? There is a spring that constantly tries to keep it disengaged, so unless you do the poor mans mod to the disconnect or keep the actuator on it, it will automatically disconnect even after you manually engage it.
As of now there is only one way I can really think of helping you. Put the actuator back on the disconnect and put it in 4hi. Jack up the passenger wheel and rotate it. Does the front prop shaft rotate?
If no; your disconnect is broken. If yes, the disconnect is working but your TC is not engaging and you need to get a proper TCCM on it.
-Wahugg
Wahugg
by tarsh » Tue Mar 18, 2014 9:40 pm
I did follow the chart. It lead me to likely the transfercase. Again. My brothers being skeptics. They drive 90's jeeps, so no computer nothing there. I trust your guys'..s information. You definitely know tons more about this than I. But, I'm learning. Now, I know that when I lift both tires of the ground rotating the passenger tire, the drivers tire does rotate, but ever so slightly. It rotates the opposite direction . Which I think it's correct . Am I wrong?
tarsh
by Wahugg » Tue Mar 18, 2014 9:44 pm
Only jack up just the passenger side. It is good news that the drivers side wheel rotates, but it could just be the disconnect is only partially engaged or that residual friction is allowing the drivers side wheel to rotate slightly.
Jack up just the passenger wheel, watch the front prop shaft, tell us what happens. Then we'll get somewhere.
-Wahugg
Wahugg
by tarsh » Tue Mar 18, 2014 9:48 pm
It rotates. Which is leading me to believe the tcase
tarsh
by Wahugg » Tue Mar 18, 2014 9:52 pm
You're correct! It is your transfer-case or the TCCM that is attached to it.
Now we don't know if your clutches are toast or if the TCCM is just dead. Before you drop money on a new TCCM, try and find a buddy with a trailblazer that has a 4x4 system known to work. Slap it on your TB, see if it works. If 4x4 works, the TCCM was your problem. Get a new TCCM and put new Autotrack II fluid in it and you should be good to go!
If not, then your clutches are burnt and you need a new TC.
-Wahugg
Wahugg
by tarsh » Tue Mar 18, 2014 9:59 pm
Autotrack whata?
tarsh
by Wahugg » Tue Mar 18, 2014 11:01 pm
A quick local search of Autotrac 2 brings up lots of information.
We're here to help you, but you gotta take some effort and search up terms.
-Wahugg
Wahugg
by tarsh » Tue Mar 18, 2014 11:07 pm
I did that actually
tarsh
by tarsh » Sat Mar 22, 2014 10:58 am
Found the problem :facepalm:
Made lots of rucouse going down the road.
Problem presented itself :mechanic: local salvage here I come.running ATF. Supposedly ok for a transfercase. What's your thoughts
tarsh
by navigator » Sat Mar 22, 2014 11:32 am
AutoTrac II only which you can pretty much only get from the dealer.
by The Roadie » Sat Mar 22, 2014 12:57 pm
tarsh wrote:running ATF. Supposedly ok for a transfercase. What's your thoughts
Auto Trak II. Accept no substitutes. Other transfer cases are not like ours. Also well-documented as the only fluid to use.
by tarsh » Sat Mar 22, 2014 6:51 pm
Yeah. I will get some later in the week. Dealer item only of course
tarsh
by DustinC1989 » Sat Mar 22, 2014 7:22 pm
$16 at the dealer every 50k miles isn't bad
DustinC1989
by tarsh » Sat Mar 22, 2014 7:30 pm
Being a dealer item I expected 60 bucks
tarsh
