Cruise Control Issue
by CNCwell » Tue Mar 18, 2014 8:19 am
While driving this morning the TB developed an issue with the cruise control. It cruises fine but when it drops gears to compensate for a hill the cruise will kick off when the RPMs hit 2964. The weird thing is that when i hit resume on the cruise it will work just fine over 2964 RPMs. It seems to only happen after cruising. Any thoughts?
--Anais Nin
All my money
CNCwell
by The Roadie » Tue Mar 18, 2014 10:15 am
First such report I remember seeing. Cruise will also drop out for certain obdii codes. Maybe you have an intermittent misfire at high RPM under load? Can you check code history and look for intermittents?
by CNCwell » Tue Mar 18, 2014 10:18 am
The Roadie wrote:First such report I remember seeing. Cruise will also drop out for certain obdii codes. Maybe you have an intermittent misfire at high RPM under load? Can you check code history and look for intermittents?
I will do that now. Luckily I now have the Torque app so I should be able to pull it from there.
--Anais Nin
All my money
CNCwell
by CNCwell » Tue Mar 18, 2014 10:26 am
No dice on the fault codes. The scan came back clean.
--Anais Nin
All my money
CNCwell
by navigator » Tue Mar 18, 2014 10:34 am
mine kicks out when towing my boat sometimes.
It seems to tow to the ramp fine but many times on the way home it won't work.
by CNCwell » Tue Mar 18, 2014 10:47 am
navigator wrote:mine kicks out when towing my boat sometimes.
Do you think that has anything to do with the transmission? If I remember correctly doesn't the cruise take its queues from the transmission?
--Anais Nin
All my money
CNCwell
by bgwolfpack » Tue Mar 18, 2014 11:00 am
I've had mine kick-out also at high rpm. I haven't looked in the book to see why, but I do not think it is an issue, just seems like it should.
by The Roadie » Tue Mar 18, 2014 11:04 am
I think it can also kick out at full pedal travel, same as the AC compressor will cut out to give you more power because it assumes you are in a passing situation. The full commanded pedal travel algorithm might also be triggered by the cruise control commanded downshift with full "virtual" pedal travel.
Remember when cruise controls had huge vacuum-powered servo motors that pulled on a cable in parallel to the pedal cable, and you could feel the pedal move up and down? Stone knives and bear claws.... :facepalm:
by CNCwell » Tue Mar 18, 2014 11:17 am
The Roadie wrote:I think it can also kick out at full pedal travel, same as the AC compressor will cut out to give you more power because it assumes you are in a passing situation. The full commanded pedal travel algorithm might also be triggered by the cruise control commanded downshift with full "virtual" pedal travel.
Ha Ha, Nice!
Thanks everyone. I will keep an eye on it and see what happens.
--Anais Nin
All my money
CNCwell
by dvanbramer88 » Tue Mar 18, 2014 11:39 am
The Roadie wrote:Remember when cruise controls had huge vacuum-powered servo motors that pulled on a cable in parallel to the pedal cable, and you could feel the pedal move up and down? Stone knives and bear claws.... :facepalm:
You mean like mine? Minus the vacuum part. Haha.
by JCrayton99 » Thu Mar 20, 2014 10:33 pm
I had an issue with cruise for a few years (I seldom used it) and could never figure out what it was. It would cruise fine from anywhere from a few seconds to a few minutes. I couldnt narrow it down to anything that caused it to drop out. Then one day it was fixed? So I was never able to track it down and this was a waste of a post.
JCrayton99
Rank: Offroad Guide
by KingBird » Sun Mar 23, 2014 3:38 pm
KingBird
