by v7guy » Fri Mar 07, 2014 3:56 am
Why would you drill the ball joint?
Are you talking about the tie rod end, and calling it a ball joint?
If you didn't drill it with a reamer the knuckle/spindle is likely junk. If you used a reamer and it's just too big, then you might be able to make a sheet metal spacer. I got a spare pair of spindles I could sell you if you need em.
Right now, with the info you've provided I have no clue what you're talking about. The preceding comments are just guesses
