by Conner299 » Sun Mar 09, 2014 9:55 pm
Conner299
by The Roadie » Sun Mar 09, 2014 10:23 pm
Back home safe. 4 hours wrenching for two of us. 6 hours driving. No vandalism. Being very careful and safe on sand. 85 degrees. Went through a gallon of water each. Pics later. Opted to replace ball joint in place, not the whole lca.
You won't believe it, but it broke before it fell apart! The broken stud stayed in the cup, with about 1/8" engagement, until I went zero - G on that tire for an instant. Then it popped out. Can tell from the wear on the broken bits.
by Moots1288 » Sun Mar 09, 2014 10:37 pm
by DirtyBacon04 » Sun Mar 09, 2014 11:22 pm
ok, I'll turn around and head back home now.
Glad you got back safely
by The Roadie » Mon Mar 10, 2014 9:10 am
I need a new local sidekick before I wheel it hard again.
by HARDTRAILZ » Mon Mar 10, 2014 9:25 am
I just could not live in that state, but would like to wheel sometime. Just need to hit the casino...but my big $11.32 jackpot this weekend was later lost.
by galacticfuzz » Wed Mar 12, 2014 1:58 pm
Made my oil skid. 3/16" thick.
galacticfuzz
by v7guy » Thu Mar 13, 2014 12:20 am
Drew, was there any reason you didn't put a wing on the other side?
by galacticfuzz » Thu Mar 13, 2014 7:34 am
That would be a slight oversight on my part to do that. I had been looking at the mdb skids as a reference when making my template from the plastic deflector.
galacticfuzz
by Trail X » Sat Mar 15, 2014 10:14 pm
Replaced the a/c pulley bearing.
I'm got so tired of squeezing the fan shroud by the radiator output tube that I decided to cut a clearance hole in the shroud and cover it up with a plate. Maybe it will save me some curse words next time.
by NC_IslandRunner » Sat Mar 15, 2014 11:26 pm
Hooked up the battery charger and started the old girl up, first I've touched my rig in 6 weeks. Power steering is gone too, time to start ordering parts.
by DustinC1989 » Sun Mar 16, 2014 12:57 pm
Hit a pothole...
ABS and Service Stabilitrak are on now.....
DustinC1989
by dvanbramer88 » Sun Mar 16, 2014 1:57 pm
Go hit the same pothole in reverse.
by Cable810 » Sun Mar 16, 2014 3:46 pm
by bgwolfpack » Sun Mar 16, 2014 4:18 pm
by Moots1288 » Sun Mar 16, 2014 4:23 pm
by DustinC1989 » Sun Mar 16, 2014 4:32 pm
Sorry moots... Michigan has you guys beat this year
DustinC1989
by Moots1288 » Sun Mar 16, 2014 8:25 pm
by dvanbramer88 » Sun Mar 16, 2014 11:19 pm
by Moots1288 » Sun Mar 16, 2014 11:20 pm
