Skid Plate
by dlcsjoyce » Fri Nov 12, 2010 7:38 pm
Well I brought home a piece of 3/16 steel plate from work, going to try and make my own oil pan skid plate hopefully I want be wasting my time and 30 dollars worth of steel. I will post pics of process. I also have most of a hitch mount spare tire carrier welded up riding around in the cargo area it's been a pain in the but to get in and out to work on at work having broke the lift gate handle the other day.
dlcsjoyce
by Trail X » Sat Nov 13, 2010 1:03 am
:need pics:
:happy whip:
by djthumper » Sat Nov 13, 2010 2:11 am
:Iagree:
by dlcsjoyce » Sat Nov 13, 2010 2:57 am
Hopefully this will work to see pics.
dlcsjoyce
by bartonmd » Sat Nov 13, 2010 8:19 am
Remember the hole for, and to build up 1/2" for the drain plug to stick through... see my skid plate thread in my section to see what I'm talking about...
by Trail X » Sat Nov 13, 2010 12:07 pm
Cool, looks like you figured out how to post the pics!
For the drop-down, will you have to unbolt one of your bolts in order to drop it down? You might want to replace one of those with a pin.
They also look a tad small.. is that a 3/8" bolt? I think mine were 3/4" grade 8s.
by dlcsjoyce » Sat Nov 13, 2010 11:10 pm
The bolts are 1/2" that was the biggest drill bit I could find at the time, and they are in it just to mock it up. I plan on using grade 8 bolts to hold everything together and regular hitch pin above the pivot point. I still plan on cutting a piece for a hi lift jack but not having on to go by I need to figure out about how long and the bolt spacing to bolt it down. Thanks for the input it pushes me to try and finish asap.
dlcsjoyce
by fishsticks » Sun Nov 14, 2010 3:39 pm
dlcsjoyce wrote:The bolts are 1/2" that was the biggest drill bit I could find at the time, and they are in it just to mock it up. I plan on using grade 8 bolts to hold everything together and regular hitch pin above the pivot point. I still plan on cutting a piece for a hi lift jack but not having on to go by I need to figure out about how long and the bolt spacing to bolt it down. Thanks for the input it pushes me to try and finish asap.
My hinge is a 1/2" grade 8 bolt, and my pin is a 1/2" pin. Zero issues.
Step bits are your friend. :)
