Bluetooth OBD2 adapter + Torque = Scangauge on crack.
by TangoBravo » Fri Apr 15, 2011 9:59 pm
The Roadie wrote:I just got a $20 cheapie from EBay vendor tomtom. Worked fine but I had to Google for the nonstandard pairing code 6789. Came in about ten days from China.
Note: Chinese electronics are OK, and I've visited many of their plants. I just think they source a lot of suspension crap parts.
Cool thanks Roadie
TangoBravo
by Philberto » Sun Apr 17, 2011 5:27 pm
Finally picked up my ELM327 for $20 from Amazon retailer dependableresource. I hooked it up, and I have to say I'm damn impressed. For a total of $20 in parts, I have something that makes the Scangauge look like a ripoff... Torque free is a little buggy, and I wanted to know if anybody noticed any bugs with the paid version before I jump into that. Also, thinking of getting a tablet for a bigger gauge display!
by Kuchar09 » Fri May 27, 2011 3:22 pm
Hey just wanted to let everyone know that the torque app finally displays the tranny temp and more!! Unfortunately it does not work with the cheap ebay clones (well mine at least). I emailed Ian about this issue and apparently my adapter kept throwing error and would freeze after 5 seconds, so hopefully all of yours will actually work. Neither of the auto PID's(method 1 and 2) work for the tranny temp you need to go to your setting and manage custom PID's. Once you are there choose "Add predefined set" for GM. Once it adds a bunch of PID's you can go to add a gauge and choose tranny.fld.temp. (I think that's what its called).
I also noticed that the fuel gauge never worked so I did some research on GM PID's and came across one that I used and it worked to make a Oil Life, Fuel Level, and also Engine Oil Temp gauge. This is the website I used http://www.scangauge.com/support/pdfs/XGAUGE.pdf
Hope this helps you guys figure it out!!!
Since my ebay clone didn't work with the tranny I ended up buying this. http://www.amazon.com/PLX-Devices-Kiwi-Blue-Tooth-Bluetooth/dp/B004B0C1NE/ref=sr_1_1?ie=UTF8&qid=1306523971&sr=8-1 And it is working great so far.
Oh and there is also a Trailblazer theme that looks much like our gauges which is cool, I was using that but for some reason it decided to make my gauges blue and yellow in the pictures.
Here are some of the gauges that I was messing with.
Kuchar09
by mikepeters1983 » Fri May 27, 2011 3:29 pm
Kuchar09 wrote:Hey just wanted to let everyone know that the torque app finally displays the tranny temp and more!! Unfortunately it does not work with the cheap ebay clones (well mine at least). I emailed Ian about this issue and apparently my adapter kept throwing error and would freeze after 5 seconds, so hopefully all of yours will actually work. Neither of the auto PID's(method 1 and 2) work for the tranny temp you need to go to your setting and manage custom PID's. Once you are there choose "Add predefined set" for GM. Once it adds a bunch of PID's you can go to add a gauge and choose tranny.fld.temp. (I think that's what its called).
now is that view on a computer?
Sorry last pic did not load. So that was on your phone then?
mikepeters1983
Vehicle: GMC Envoy XUV
DriveTrain: 2WD w/ G80
by Kuchar09 » Fri May 27, 2011 3:47 pm
Yup this is on my phone Motorola Droid 1.
Here is another pic, its suppose to be red and blue but you get the idea.
Kuchar09
by ironman_markv » Fri May 27, 2011 9:42 pm
so im gunna sound like the noob here but this device is semi-permanently hooked up to your OBD port and you can get real time feeds off of it to see how your vehicle is running?
ironman_markv
by Kuchar09 » Fri May 27, 2011 10:23 pm
ironman_markv wrote:so im gunna sound like the noob here but this device is semi-permanently hooked up to your OBD port and you can get real time feeds off of it to see how your vehicle is running?
I am running the http://www.amazon.com/PLX-Devices-Kiwi-Blue-Tooth-Bluetooth/dp/B004B0C1NE/ref=sr_1_1?ie=UTF8&qid=1306523971&sr=8-1 which has a 6ft cable which is unnecessary but I ran it under my dash and hid the main Bluetooth module under the dash. Once that is hooked you can leave it alone and just use your phone to connect to it wireless with your phone using Bluetooth.
Kuchar09
by ironman_markv » Sat May 28, 2011 7:48 am
so i would assume like any other tech, if u have a bluetooth device u can sync it to it, like a tablet or something
ironman_markv
by DmccartneyFF2TB » Sat May 28, 2011 8:01 am
I like the way this is set up wish it worked with the itouch I just go with the other one I wa looking at.
Dame
BDS,ROUGH COUNTRY,
Smitty Build XR-C8 Winch
www.wm4x4.com
DmccartneyFF2TB
by Kuchar09 » Sat May 28, 2011 11:03 am
ironman_markv wrote:so i would assume like any other tech, if u have a bluetooth device u can sync it to it, like a tablet or something
I believe as long as it is an android device it will work.
Kuchar09
by james02 » Wed Aug 14, 2013 11:07 am
Got a chance to tool around with this yesterday.....So far so good... Hows everybody liking theirs now days?
james02
by Conner299 » Wed Aug 14, 2013 9:34 pm
I literally use mine everyday. Just wish we had a "real" oil pressure sensor.
Conner299
by james02 » Thu Aug 15, 2013 11:55 am
Had the free version...Just ordered the paid version...Might be the first app I've ever bought...
james02
by plaen » Mon Aug 19, 2013 4:32 pm
james02 wrote:Had the free version...Just ordered the paid version...Might be the first app I've ever bought...
It's the only one I've bought, best 25($20 adapter) bucks I've ever spent. I have mine set to pull codes log and reset them when they occur, since I have a crap APPS and it trips the reduced engine power. Recently been getting a pending cam shaft sensor code, let it run for a week without resetting and it never became permanent.
plaen
by boog2006 » Fri Dec 27, 2013 3:24 pm
Roadie would be proud. I just swithed from an Iphone 4s to a Samsung Galaxy S4. :D I hope to have the bluetooth OBD2 adapterand torque running soon.
Time to read this thread thoroughly... :coffee:
Boog2006 Build Thread
boog2006
by HARDTRAILZ » Fri Dec 27, 2013 3:30 pm
I have the free version and have used the adaptor several time recently to check for codes when looking at used vans for the wife. Pretty handy.
by NC_IslandRunner » Fri Dec 27, 2013 3:35 pm
boog2006 wrote:Roadie would be proud. I just swithed from an Iphone 4s to a Samsung Galaxy S4. :D I hope to have the bluetooth OBD2 adapterand torque running soon.
He would still not be proud, he would have Garfield swat you with a newspaper with a caption about spelling! :finger:
by boog2006 » Fri Dec 27, 2013 3:54 pm
:wallbash:
boog2006
