by Eredin » Sun Mar 15, 2015 2:28 am
Dropped the rear sway bar out, had to cut the end links off, nuts are seized to the threads. I'll deal with getting the remainder out at a later time, if needed. Found that the N8030 shock bushings are looser than I thought so I need to figure out what to do to fix the bushing collar play. Discovered my lower pan hard bar now has some noise, bushing starting to get weak. Popped the front bumper cover out, snow mound pushed the corner in sometime last week, ready to get rid of it and build one from Mike. Passenger side CV is slinging grease out the end, so dropped a 4" worm clamp on it to see if that will resolve. Driver side isn't leaking yet, so leaving it be. Diff still leaking, but not bad. Still searching for 4.10 front/rear to swap in. Have some good buys on 8.6 rears that are close enough, but can't take a day off from new job for a few more weeks to go get them and the fronts don't seem to be too common. Also trying to figure out what I want to do for a spare tire carrier. I'd like a gate or a fold down, roof rack wrecks mileage to bad to warrant. Lots of stuff, hopefully more soon. Spring is here, itch to get out and work on stuff again has bit.
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
