by mikekey » Wed Dec 18, 2013 3:17 pm
I have the 4ft one too and no hitting of the truck or whipping.
by blazinlow89 » Wed Dec 18, 2013 3:55 pm
James I assumed that the self tapping screws would not be the best thing for longevity. Used the JB weld to hopefully make a nice bond with the threads, will most likely switch to bolts and nuts in the next month or so to make it permanent.
blazinlow89
by mikekey » Wed Dec 18, 2013 4:19 pm
The sheet metal is like tin back there. That's the problem. Might as well put a screw threw a can.
by OregTrailBlazin » Wed Dec 18, 2013 5:41 pm
I did all the steppers in my Dash this last weekend.. Everything came out great, except the Speedo. Its still doing the same thing, just moves in one direction, and very jerky. Not smooth like the other gauges. I hope I didn't fry the board, I haven't done too much soldering on boards. It looks fine, I'm hoping/wishing/praying its a bad sending unit..... Anyone have any experience on this?
Johnny Kurz
General Manager
541-474-2879
Wheeler's Off-Road Inc.
Our Vendor Section
OregTrailBlazin
by The Roadie » Wed Dec 18, 2013 6:26 pm
I've soldered a couple of things in 40 years.
The sensor being bad would screw up shift points and a LOT of other stuff. If you had a scan tool or the Torque app to look at the data, you could confirm the sensor.
A needle that jerks and goes only one way could be a bad solder connection or a mechanically binding stepper. Gotta take it apart again either way.
by OregTrailBlazin » Wed Dec 18, 2013 6:47 pm
The Roadie wrote:I've soldered a couple of things in 40 years.
I switched it out with another new stepper already to make sure the first one wasn't defective, and made sure the solder connections were good (no pits, missing solder, and all the way around the pin on the solder pad). So probably burnt the board.. Bummer, I did so well on the others :(
Johnny Kurz
General Manager
541-474-2879
Our Vendor Section
OregTrailBlazin
by hayes » Wed Dec 18, 2013 7:42 pm
Aries wrote:Installed:
  • Z71 Rear Springs
  • BDS 55619 Rear Shocks
  • Massive adjustable pan hard bar
  • Liftmeister 1.5/ 6x5.5 wheel adapters
  • 265/75R16 GUARD DOGS on H3 Wheels
  • Removed Rear Sway Bar
got any pics?
hayes
by blazinlow89 » Thu Dec 19, 2013 12:18 am
mikekey wrote:The sheet metal is like tin back there. That's the problem. Might as well put a screw threw a can.
Yeah the drill bit did not take long to go though for the pilot holes. On a good note I will already have the pilot holes drilled for when I do switch to bolts.
I also need to ground it better, picked up a ton of static on a few channels, others were crystal clear. The placement is honestly perfect, I can adjust anything I need to without looking away from the road. The screen does get washed out with sunlight, but that is fine when I am driving.
blazinlow89
by HARDTRAILZ » Thu Dec 19, 2013 9:39 am
Ordered the fifth tire so I can do the first rotation with all 5.
Was an eye opener when the set of 4 tires for the TDI Jetta I ordered for my parents cost less than one of mine.
by blazinlow89 » Thu Dec 19, 2013 10:27 am
Car tires are always so much cheaper, I think 4 tires for the Jetta with 18" wheels was like $400 installed. I have not even priced tires around your size, I know it's a bigger chunk of change than the ones I am pricing.
blazinlow89
by mikekey » Thu Dec 19, 2013 10:31 am
The tires for the GXP aren't cheap if that makes you feel any better.
by HARDTRAILZ » Thu Dec 19, 2013 10:56 am
These are just the little 205 16, so they were cheap. My F-Body tires cost a decent little bit but it is crazy how much tire prices have gone up since I started buying big mud tire 15 years ago. $100 each for swampers was expensive, now I would buy truck loads at that.
by Trail X » Thu Dec 19, 2013 11:50 am
Tire prices do seem to have soared recently.
Doing some research, seems there was a rubber boom recently, through '09 and '10. Prices really skyrocketed then, and I think tire companies have yet to bring their prices down. My bet is that since tire prices reached a new norm during that time, the companies have been enjoying some extra profit, and are a bit reluctant to reduce that margin, especially on the larger tires that aren't as "price driven" as the passenger tire market.
by HARDTRAILZ » Thu Dec 19, 2013 12:12 pm
I have never seen tire prices for our kinda tires go down.
by blazinlow89 » Thu Dec 19, 2013 1:43 pm
I got those ATRs for a steal. I was assuming it was a misprint or old stock so I dtd price match. Granted they are not like the tires most of you run. Purchasing new ones spring next year after the wedding. I know I'm getting 265/75/16, debating on brand right now.
blazinlow89
by Aries » Thu Dec 19, 2013 8:37 pm
Inspected components, new shaft seals, re-greased and added zerk fitting to spare front disconnect. Replacement front axle should be here tomorrow.
Aries
by galacticfuzz » Thu Dec 19, 2013 9:04 pm
Completed my spare tire and hilift carrier. Image
― Antonio Porchia
galacticfuzz
by blazinlow89 » Fri Dec 20, 2013 8:47 am
Can you a get side pic of it mounted? Looking at getting one from detour that swings to the side. They also have a 2" adapter that bolts to the straight portion of the hitch, however I have yet to examine the hitch to see if it will work.
It looks good though.
blazinlow89
by galacticfuzz » Fri Dec 20, 2013 12:23 pm
blazinlow89 wrote:Can you a get side pic of it mounted? Looking at getting one from detour that swings to the side. They also have a 2" adapter that bolts to the straight portion of the hitch, however I have yet to examine the hitch to see if it will work.
― Antonio Porchia
galacticfuzz
by Moots1288 » Fri Dec 20, 2013 12:44 pm
Found out that the dealership by me is a bunch of incompetent assholed
