Steering (Problem Solved)
by signguy62 » Tue Feb 02, 2010 11:32 am
My steering wheel wobbles/saws back and forth, more pronounced at low speed,decreases as speed increases. and it's pulling to the left. Could this be a tire problem?
signguy62
by Trail X » Tue Feb 02, 2010 11:53 am
Is the wobble synchronous with the tire RPMs?
Does the body roll with the wobbles?
Are you lifted?
Have you ran your hand around the tread of the tire? Be sure to check the interior and exterior of the treads.
Have you looked down at the tire while traveling at a low speed? If there is a belt broken, it can appear that the tire is wobbling.
by Zero » Tue Feb 02, 2010 12:42 pm
are your wheels balanced? Have you checked the psi in the tires? When was the last time you had an alignment?
by signguy62 » Tue Feb 02, 2010 2:37 pm
This just started when I removed my 22's and put my stock 17's back on. Alignment was done back in the summer. And the wobble does seem synced with the tire revolution. Will have to look at the tire closer. And not lifted yet, still lowered but on my way to lifting.
signguy62
by Zero » Tue Feb 02, 2010 2:52 pm
Did you have your truck re aligned after the wheel and tire swap? Have you checked the balljoints?
by Trail X » Tue Feb 02, 2010 3:46 pm
signguy62 wrote:This just started when I removed my 22's and put my stock 17's back on.
If it was immediately after you changed back, check your front tires to make sure they are seated properly on the hub. You may have a wobbling wheel... potentially very dangerous.
by Gordinho80 » Tue Feb 02, 2010 3:52 pm
Agreed! Just ask Alex over on the OS.
Welcome to the dark side, Jim. Why the change of heart? :safari:
by signguy62 » Wed Feb 03, 2010 10:57 am
Been running low for a very long time. First my Silverado and then the TB. Just looking for a change and with all the fire trails/roads around here, I figure I'll have some fun.
Wheel seems to be seated just fine. But I did not have it re-aligned when I took the 22's off. Another thing though, I had to be in work this AM @ 4 and noticed that with the snow covered roads the steering wheel didn't wobble. I still think it's the tire.
signguy62
by OregTrailBlazin » Wed Feb 03, 2010 2:10 pm
signguy62 wrote: snow covered roads the steering wheel didn't wobble. I still think it's the tire.
Sounds like it could be, have you felt up your tires yet to see if they have any bulges or signs of broken belting like James suggested? Like he was saying, you can hang your head out the window, and a friend out the other side to see if you can see any signs of wobbling...
Where is around here??
Last edited by OregTrailBlazin on Thu Feb 04, 2010 1:17 pm, edited 1 time in total.
Johnny Kurz
General Manager
541-474-2879
Wheeler's Off-Road Inc.
Our Vendor Section
OregTrailBlazin
by signguy62 » Wed Feb 03, 2010 3:26 pm
Yeah, I'll have to take a close look at the tires.
Around here is the Pine Barrens of NJ.
signguy62
by Gordinho80 » Wed Feb 03, 2010 3:30 pm
Yeah...Jim is a Jersey Boy... :flex dirty:
by janesy86 » Wed Feb 03, 2010 4:01 pm
Damn, there are a lot of you Jersey guys... well minus Bot now. What a shame.
But back on topic, that's is a little weird tho that you only get the wobble at lower speeds but, I'm also thinkin' it's the tires or tire.
by irishboy02 » Thu Feb 04, 2010 2:39 am
janesy86 wrote:Damn, there are a lot of you Jersey guys..
Yeah, so what. Gotta problem!? :shoot:
:coffee:
We need to find new spots to wheel around here, not to mention wharton takes me over half a tank of gas to get to :drive:
We need to get all us Jersey guys out soon.
2003 GMC Sierra z71
7" FTS lift
irishboy02
by Philberto » Thu Feb 04, 2010 3:35 am
:hijack:
Oh, I wish most offroading out here ONLY took a half a tank of gas to get to... count your blessings. :flex dirty:
by The Roadie » Thu Feb 04, 2010 3:23 pm
Philberto wrote:Oh, I wish most offroading out here ONLY took a half a tank of gas to get to...
Yeah, but. When we get there it's ten times more impressive scenery-wise, so it evens out. :cheers:
by irishboy02 » Fri Feb 05, 2010 2:08 am
Yea, but its okay. We make due with what we have.
Signguy, (Jim?), how were your tires stored?
Often, if a tire is not stored the proper way, it will loose its balancing and or warp a certain way to contour to its surroundings. When the rubber softens due to temp, humidity, moisture etc. it will form around its new low points, causing the actual tire to loose its stability and balance. This could be your issue.
2003 GMC Sierra z71
7" FTS lift
irishboy02
by signguy62 » Fri Feb 05, 2010 9:07 am
They were stored on their side, stacked 4 high in my shed. But I think I found the problem.......I think its a messed up steel belt. Might have damaged it on a pot hole or something.
(Problem Solved) It was a bad spot on the passenger side front tire.
signguy62
