by irishboy02 » Fri Feb 05, 2010 2:08 am
Yea, but its okay. We make due with what we have.
Signguy, (Jim?), how were your tires stored?
Often, if a tire is not stored the proper way, it will loose its balancing and or warp a certain way to contour to its surroundings. When the rubber softens due to temp, humidity, moisture etc. it will form around its new low points, causing the actual tire to loose its stability and balance. This could be your issue.
Gettin' Dirrty in Jersey
2003 GMC Sierra z71
7" FTS lift
