irishboy02 wrote:What if we cure that upper balljoint issue? (insert chin rubbing smilie here)
If we can straighten out the balljoint issue (no pun intended) does anyone have any objectiong to run this setup?
The Roadie wrote:Inside the strut and outside the strut spacers don't interact in any way that has to do with stacking. And the upper strut mount bolts aren't stressed in tension unless you fully extend the strut and hit the shock's internal stop. Am I missing what you intend to do? Why worry about those upper bolts?
And no shop can fix an alignment problem if the adjustment slots are maxed out. I'm putting in some fresh Mevotech lower control arms and brackets this weekend, and will be trying to safely increase the slottage for more camber adjustment range.
teamred250ex wrote:sooo from what im understanding,
1. it can be done
2. not recommended for serious offroading
3. may have alignment problems, i don't understand why that would occur?
Zero wrote:The only thing I have to say is I agree with our BDS vendor. I dont want you driving next to me or my family with a set up like that.
There are reasons these companies only sell 2" lifts.....they have spent thousands of hours and dollars testing and making sure things are safe.
I want you to sit down, and clearly ask yourself. IS MY LIFE WORTH 2" OF LIFT????? Bro I hope you say no. DOnt risk your life and others on the road next to you.
If your gona do something like this go all out completely custom. Dnt half ass it. You will never get what you want, youll never be happy, and your parts will never last.
teamred250ex wrote:I feel the same way, thats why i wanted to get everyones opinions if it was safe or not. The extra lift would be great but its not worth hurting anyone or myself in the process. I guess i will be looking into a body lift. Is markmc still making the 3" kits?
Totally agree. I resisted a body lift for a LONG time, and when I finally had to admit I needed it, I went with the 2" to be able to fit 33-34" tires and not raise my COG as much as the 3". That decision cost me because by the time I added the body lift, I had already had rock sliders welded to the frame, and the total custom front bumper was fabbed to fit the OEM height. Took Neil and his sidekick about 16-18 man-hours to relocate that stuff upwards the 2" and make it look good.HARDTRAILZ wrote:height is not nearly as important as other factors in wheeling. the lower the better if it accomplishes your goal.
