by BDS Suspension » Fri Apr 23, 2010 8:48 am
2+2 does not equal 4 in this case. It will be much higher then that. With that setup on a stock vehicle you will not have any suspension travel. You will be setting on the upper limits of the suspension. Dangerous. Adding that much additional length to the strut will actually preload the ball joints. Basically the joints will be maxed out AND have additional spring pressure against them.
Pretty easy way to illustrate this for someone wanting a weekend project. Remove your strut and reassembly the front suspension without it. Allow your suspension to hang...even use a long prybar to max it out. Measure the distance front the upper strut mounting surface (frame mount) to the center of the lower strut mount (control arm mount). This is the MAX overall strut length that should be installed in the vehicle. Anything beyond that will require you to compress the strut to attach the upper ball joint. That puts spring load on the ball joint that was never intended to have a load like that applied. Basically trying to pull the ball joint out of the socket. Even worse, at full droop the ball joint is at an angle, making it even easier to pry out of the socket. For an example, let's just say the front coils have a rate of 500 lbs (I honestly don't remember what they are exactly). If you install a strut assembly that is 1" longer then the overall space we measured, that means we have to compress the spring the 1" to install it....that puts 500 lbs of pressure on the upper ball joint that was not intended to be loaded in that direction. A major failure waiting to happen.
We go through this topic almost daily here with all different types of vehicles...everyone is always looking for that extra inch for next to nothing. I am here to tell you it is not worth it! You might says you are willing to take the chance since you don't wheel your vehicle....my response to that is if you run something like this, the only place I would want to see your vehicle is on the trail. I don't want it on the road driving next to me, my wife and my 2 daughters. If....I mean when that upper ball joint decides to go you are not going to have any control of your vehicle.
