offroadTB.com • View topic - Another wheel spacer not fitting well (maybe) post
by SPEEDRACER30 » Sat Jan 18, 2014 11:11 am
I ordered my wheel spacers from MarkMC in the 6x5.0 flavor, and while I know hub-centric wheels can be a bit "tight", mine are ridiculously tight. Like when torqued down it is shaving aluminum off of my stock wheels! Anybody else encounter this problem from Mark's spacers, or am I just lucky? :scratch:
SPEEDRACER30
by DirtyBacon04 » Sat Jan 18, 2014 11:50 am
are you still running stock hubs? Ive never heard of that issue with marks parts. I'd contact him to verify.
by Moots1288 » Sat Jan 18, 2014 12:26 pm
by SPEEDRACER30 » Sat Jan 18, 2014 12:42 pm
SPEEDRACER30
by mikekey » Sat Jan 18, 2014 1:54 pm
Never heard of that, you have stock wheels, correct?
by Moots1288 » Sat Jan 18, 2014 1:58 pm
by SPEEDRACER30 » Sat Jan 18, 2014 2:18 pm
SPEEDRACER30
by PapaBear229 » Sat Jan 18, 2014 2:25 pm
PapaBear229
by SPEEDRACER30 » Sat Jan 18, 2014 2:33 pm
Sounds like this is pretty common for some, so I am not going to worry about it until they get rotated. Sounds like a bit of grease or slight filing might be warranted. Maybe just filing a slight bevel in the back side of the wheel might keep it from dragging on the spacer a bit.
SPEEDRACER30
by Trail X » Sat Jan 18, 2014 4:39 pm
Sounds like Mark needs to tighten up that bore a bit on the spacer. The lip isn't supposed to take any real stress, only provide an alignment guide so the wheel's weight isn't sitting on the studs upon install.
by HARDTRAILZ » Sun Jan 19, 2014 3:00 am
Sounds pretty //// far from common.
by Regulator1175 » Sun Jan 19, 2014 3:04 am
Here's an idea, set your truck on fire. It is the best solution! Oh, and way to support your vendor's James. One complaint and no one cares about the hundreds of satisfied customers he has!
Sent from my SCH-I545 using Tapatalk
by hotness » Sun Jan 19, 2014 3:05 am
Far from common. Do some research first.
hotness
by v7guy » Sun Jan 19, 2014 6:25 am
Sounds like they're a bit oversized. At the proper size (from my experience) they should fit snug, with some anti sieze the wheel should come off with little difficulty. They definitely shouldn't be shaving aluminum off.
There has been a mix up with Marks wheel studs recently. Maybe his machinist is getting lazy.
I'd contact Mark, he's well known for having amazing customer service.
by HARDTRAILZ » Sun Jan 19, 2014 8:13 am
by Trail X » Sun Jan 19, 2014 10:59 am
by Cable810 » Sun Jan 19, 2014 7:21 pm
by Dammann35 » Sun Jan 19, 2014 7:26 pm
I have the same problem with stock 16in wheels but it does affect anything. I just have to hit the back side of my tire with a hammer when I take them off.
Build Thread:
Dammann35
by SPEEDRACER30 » Mon Jan 20, 2014 9:05 am
Well I guess at bare minimum I will let Mark know about the minor issue so the mold can be checked. Either way it is not that big of an issue. They still work fine and serve their purpose that they were intended for and I am still impressed with Mark's products. Didn't mean to open a can of worms.
SPEEDRACER30
by v7guy » Mon Jan 20, 2014 10:56 am
I'd give Mark a hollar and let him know, it would be helpful if you could provide inside measurements of the wheel and of the spacers lip. The more accurate the better. With that said I'm sure the measurement tools aren't readily available to a lot of guys.
