tire questions
by mike721 » Sun Jun 13, 2010 12:24 am
so whats the biggist tire i can fit with the smaxx lift and adapters i got the 30.5 right now but i really would like to get as close to 33's as i can i got stock rims but i plan on changing those out too
mike721
by fishsticks » Sun Jun 13, 2010 12:47 am
33's on a stock wheel hmm?
For 17": (Quite possibly my next tire)
http://www.tirerack.com/tires/TireSearc ... 7&x=15&y=9
For 16":
http://www.tirerack.com/tires/TireSearc ... 6&x=18&y=8
Ready your razor knife and sawzall...
....AND! This belongs in Wheels/Tires. Not Suspension. :poke:
by The Roadie » Sun Jun 13, 2010 1:14 pm
I'm not sure there are ANY 33's that are factory spec'ed to fit on 7" wide rims. You looked closely at the tire specs yet?
The current record holders are multiple members (3 now?) with 35's, but really, that's a HUGE risk for hard offroading, given the strength of the drivetrain.
by irishboy02 » Sun Jun 13, 2010 3:25 pm
You can fit a 33x10.5 on our 7" rim no problem. I believe Mrsmithtb is running 285/70-16 IIRC.
2003 GMC Sierra z71
7" FTS lift
irishboy02
by Philberto » Sun Jun 13, 2010 3:41 pm
The Roadie wrote:I'm not sure there are ANY 33's that are factory spec'ed to fit on 7" wide rims. You looked closely at the tire specs yet?
Really Bill? Have you forgotten about the venerable 255/85? Spec'd for stock diameter rims and 33" in diameter.
by KE7WOX » Sun Jun 13, 2010 4:16 pm
Yeah seems like 255s and 10.5s would work on a 7" rim, 10.5 is slightly bigger (like 0.07in) than 265mm
by MrSmithsTB » Sun Jun 13, 2010 6:16 pm
I fit 285/75/16(33x11.25) on the stock 7" wide rim. The tires aren't spec'd for anything less than 7.5", so that would be an obvious tire warranty void. But 7 out of 10 off roaders will tell you that is doesn't create any real safety issues. It protects the bead more, and as long as they are pressurized correctly(@35psi) they will wear evenly. And at that psi, the sidewalls don't have enough flex to wander at higher speeds. I will roll with 33" tires on my stock rims again, but not until I ad some body lift to my suspension lift, and maybe re-gear my diffs.
by Zero » Sun Jun 13, 2010 9:39 pm
its always nice to get info 1st hand from someone who has done what ur asking about. :cheers:
by fishsticks » Sun Jun 13, 2010 11:49 pm
FWIW both BFG sizes I linked are factory rated for 6.5-8.5" wheels.
by Trail X » Mon Jun 21, 2010 12:49 pm
fishsticks wrote:33's on a stock wheel hmm?
For 16":
Pretty solid options there.
The 33" tire is quite glorious sounding on paper, but I'm not sure if I need the extra 1/2".
I've had my eyes on those tires since they came out though. Trying to tell myself to just stick with 32s.
by KE7WOX » Mon Jun 21, 2010 2:38 pm
For 16":
That's exactly what I was thinking, if the extra trouble was really worth it, considering what we would get only 1/2"-3/4"
